What to look or ask for on Annual Service
Old Jun 1, 2014 | 06:12 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
My 09 Vantage with 37,000 miles will be in Lake Forest for its annual service in two weeks. Besides a frayed seatbelt, and a door seal that is splitting apart along the bottom of the door, there is no visible sign of anything wrong. I know about having the software for the Sportshift updated, but what else should I ask for to be looked at the annual and to be updated under warranty or typical services?
Old Jun 1, 2014 | 06:57 AM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
I'd verify your AM radio works. An unpopular band, chances are many of us don't listen to AM and thus don't know whether or not our radios have suffered a fairly frequent failure of the AM band. I had my failed radio placed in my 09 volante right before the warranty expired last year.
Old Jun 1, 2014 | 07:40 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
My AM radio module failed in my '08 V8V; it was replaced under warrantee. Seems like a fairly common failure. Also of course have them look closely for any oil leaks, especially around the front cover.
Old Jun 1, 2014 | 09:24 AM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
supposed to change all fluids. Also, make sure the throttle pedal recall was done.
http://www.reuters.com/article/2014/...A141T120140205
Chris
Old Jun 1, 2014 | 03:31 PM
62Jeff's Avatar
Isn't there also a somewhat problematic leak at the transmission cooling lines, on those cars so equipped? I recall something about that, probably worth a forum search.
Old Jun 1, 2014 | 10:00 PM
Matrix6048's Avatar
Matrix6048 is infamous around these parts
Old Jun 2, 2014 | 03:43 AM
zvez's Avatar
this is a great link!
Originally Posted by Matrix6048
Old Jun 2, 2014 | 03:54 AM
Matrix6048's Avatar
On this web you can find also manual's after registration or another nice articles. For example: http://en.aston-martin-club.com/arti...ying-guide-128 or this information in forum: http://en.aston-martin-club.com/foru.../gaydon-era-37
Old Jun 2, 2014 | 11:08 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
This looks like it covers the full service intervals...
Old Jun 2, 2014 | 12:52 PM
Prefurbia's Avatar
I checked my AM - it works fine... it may have been replaced in the past.
Old Jun 2, 2014 | 05:58 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Oil change, transmission fluid service (highly recommend Mobil1 75w-90LS, motul600 or Castrol SRF brake fluid for sure (it's probably never been replaced so you definitely need to get this done). Cabin filter if it's never been done might not be a bad idea.
Old Jun 3, 2014 | 06:43 AM
jroback's Avatar
jroback is infamous around these parts
The AM maintenance specs indicate oil change every 10,000 miles (among other things), but I've seen others on here suggest oil change every 4-5000 miles. I guess it doesn't hurt to change oil more often than specified, but does anyone think that practice would extend engine life or reduce the likelihood of potential problems?
Old Jun 3, 2014 | 09:37 AM
dicktahoe's Avatar
I go with the manufacturer's recommendations. The Oil they use is the highest quality available and with 10-quarts it is nearly 2-times the oil in other similar sized engines. Changing more often than recommended is just a waste of $$$ and Oil. My Porsche Boxster recommendation was for 15,000 miles/every year and filter was to be changed every-other oil change. With modern oils, the main reason to change it is because of a depletion of additives and with the Aston recommended oils, depletion is not of concern for the 10,000 miles they recommend.
Old Jun 3, 2014 | 10:45 PM
Matrix6048's Avatar
Here is next from service expert information: http://en.aston-martin-club.com/arti...econd-part-187
Old Jun 4, 2014 | 06:49 AM
jroback's Avatar
Thanks Dick! Every 10k it is then...
