AMV8 Clutch Discussion
Old Jul 18, 2016 | 11:36 AM
  #31
deckman's Avatar
When my clutch goes I will definitely get an after market replacement. Those of you who have done that did you also get a lighter weight fly wheel?
Old Jul 18, 2016 | 11:39 AM
  #32
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
I replaced my worn-out stock clutch and flywheel with the VelocityAP lightweight flywheel and dual-disc clutch kit and it is absolutely fantastic. This is how the car should have been made.
Old Jul 19, 2016 | 08:42 AM
  #33
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
Originally Posted by embdenb
I posted a rant about the V8 clutch some time ago so I am not going to repeat it.
That said the clutch on the V8 AM is an indefensible weak point. I actually read somewhere that for a few years, a sub-stand clutch disk was installed V8 Aston Martins?
As others have pointed out, with the manual shift cars, shift into neutral prior to stopping.
Keep your foot off the clutch until the light changes or the cars in front of you starts to move.
Apply minimal power until the pressure plate is fully engage with the clutch disk.
I also do not down shift at slow speeds where I might have to match the clutch to the engines RPM.
If I had a SportShift I would go into neutral at stop lights unless someone can convince me otherwise.
Thanks - pity you can't downshift - it's been a part of my driving method for decades. I learned years ago to put a car in neutral at lights to take some pressure off the throw-out bearing. Also keeping your hand off the shifter as much as possible to preserve the gear-shift bushings but I'll be dammed if I'm gonna drive this thing like it's some kind of fragile china doll. I don't coast very well.
I'm not an aggressive driver and my BMW is on original brake pads and clutch at 252K so I know how to brake and shift.
Well, I might just say "been there done that - never again" Probably putting it up for sale today - I need a "true drivers car" that can actually be driven like it looks. I'll likely lose $25K-$35K or more but so far the only thing about this car that I find irresistible is the sound of the exhaust, and frankly I can emulate that sound in a modified M4 with 6 cylinders and better hp.
Gotta laugh though, as the car took first runner up last month in an all British car show here in Canada cause it was so well preserved for it's age - original owner just kept it in a glass case as part of his stable of luxury cars - does look good but I like to drive.
Thanks everyone here for your help and advice.
Old Jul 19, 2016 | 11:25 AM
  #34
embdenb's Avatar
Just a thought. If you love the car but hate the clutch, before selling it at a loss, put some of that money into the modified v12 dual disc clutch. From what I have read this solves the clutch problem.
Old Jul 19, 2016 | 12:58 PM
  #35
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
I drive mine like a sports car is meant to be driven and have never smelled any clutch. If you're properly rev matching downshifts you won't hurt the clutch at all.
Old Jul 19, 2016 | 01:13 PM
  #36
telum01's Avatar
For the manual transmission:
In my experience, both letting other people drive my car and as a passenger in other people's Astons, most people tend to ride the clutch - they give it gas too early. The release point is pretty high, which is great for sporty driving because you can just blip the clutch pedal to shift. But that leads to people giving it gas way too early and that ends up prematurely wearing out the clutch.
A good exercise that I tell people to do is to find an open, flat road or parking lot. From a dead stop, don't touch the gas pedal, just use the clutch. Release the clutch very slowly so you can feel it engaging. If you do it slow enough, you'll actually feel it grab and the car will start rolling. You never have to touch the gas pedal. Do that a few times and you'll get the hang of that engagement point. With some practice, it'll become second nature. You'll relearn when to give the car gas and your clutch will last a lot longer.
I personally think it's a matter of retraining your muscle memory so that you give it gas later compared to other manual cars.
Old Jul 19, 2016 | 02:28 PM
  #37
BMW-North's Avatar
Thanks - Worth considering but other than the body line (particularly the wide hips) and the exhaust sound I haven't found the car to be exhilarating at all. Certainly not my first pick when I head out in the morning.
Spent an hour or two reading various sources opinions on this issue and how it's been noted as a particular weak point and customer issue. I would've still bought this car however even knowing this, as I wanted to complete a bucket list item for my dad. That's done so I no longer need to keep it. It's funny reading on here how folk say that it's the driving habit that is the clutch issue - this is a bad part/design from the factory - no amount of RPM matching or using the dead pedal to avoid wear was going to avoid the issue - it's just an Aston Martin defect - period.
Can't say I'm impressed by how the company dealt with it at the time though - deny deny deny - that's something I would expect from VAG not Aston Martin.
Old Jul 19, 2016 | 03:04 PM
  #38
Kapoosh1's Avatar
Any interest in selling the clear tails before selling the car?
Old Jul 19, 2016 | 04:15 PM
  #39
embdenb's Avatar
What is so frustrating is that this problem varies in severity from car to car. I know when the clutch grabs the flywheel. I have driven manual gearbox cars all my life. (I am 71). It's insulting to me when its suggested that my driving habits is a contributing factor. I once drove the car they way I would like to, downshifting before corners and somewhat spirited on the gas. When I pulled into the garage the clutch smell was overwhelming. This after a 20 minute drive on a car with less that 5k on the odometer . I am sure others have driven much more aggressively without my symptoms. That's what's so frustrating about this issue, it seems no two cars are exactly alike. I am resigned to replacing the clutch with a dual disc unit . In the interim I will baby this as long as I can.
Old Jul 19, 2016 | 06:53 PM
  #40
superuser's Avatar
superuser is infamous around these parts
I think most cars have their weak spot and once you fix them they are solid.
  • e46 rear subframe
  • early 964 bad dualmass flywheel
  • 993 and 964 soft valve guides
My advice is drive it and fix what is needed when it comes up.
Cheers
Daryl
Old Jul 19, 2016 | 07:07 PM
  #41
BMW-North's Avatar
Thanks Daryl - Good point. I'm all too familiar with the e46 - I've owned 5 - still have 3, although never had the sub-frame issue which was just on the early models. I'll look into the feasibility for me to do the v12 clutch/flywheel swap as a possibility then decide.
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
Blue Chip
Sep 10, 2015 07:07 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
