Marker Lite
Old Jun 19, 2014 | 10:54 AM
flittlejr's Avatar
flittlejr is infamous around these parts
Question Marker Lite
Is there any way to replace left rear marker lite other than dropping the bumper like the shop manual calls for
Old Jun 19, 2014 | 12:49 PM
karlfranz's Avatar
First if all, it's probably good etiquette to make a first post introducing yourself rather than immediately starting to ask questions and expecting people to help you.
That being said, you can access the rear marker lights by removing the rear wheel liners, but it is a very tight squeeze and the posts for fastening the lights are plastic and rather delicate so it's difficult to do and you run the risk of breaking them. You can easily replace the bulb itself without taking the bumper.
Old Jun 20, 2014 | 05:36 AM
flittlejr's Avatar
Smile Etiquette
That being said, you can access the rear marker lights by removing the rear wheel liners, but it is a very tight squeeze and the posts for fastening the lights are plStic and rather delicate so it's difficult to do and you run the risk of breaking them. You can easily replace the bulb itself without taking the bumper.
Sorry but I thought I had. I get confused which forum I'm on cause most I put profile, pictures, etc.
Anyway Frank Little live in Virginia Beach, 06 db9 volante, and I'll check to make sure pictures are posted. Thanks Frank
Old Jun 20, 2014 | 05:39 AM
flittlejr's Avatar
Thumbs up Rear marker lite
So with the delicacy it's best just to take to body shop and drop the bumper like the shop manual say's. I in the middle as far as dealers, Greensboro NC or Vienna Va both 3 1/2 drives each way. Thanks Frank
Old Jun 20, 2014 | 06:25 AM
karlfranz's Avatar
Well, if your handy with tools, you could at least take a peek by removing the wheel well liner. Just know that those plastic posts on the marker lights seem to get mangled by the self-threading nuts and are easy to break. Whatever you do, don't over-torque them.
Old Jun 24, 2014 | 08:44 AM
flittlejr's Avatar
I think I'll take to local body shop. I keep a flash drive with owners manual & shop manual in glovebox in case they have questions. Frrank
Old Jun 24, 2014 | 08:15 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
Welcome Frank! The car can be intimidating to work on, but if you take your time and work carefully you will be very pleased with doing your own work.
