PArking brake pads for 2009 DB9
Old Jul 26, 2014 | 06:36 AM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Has any one use these, do they fit?
http://www.ebay.com/itm/151285410555...84.m1423.l2649
I don't want OEM due to concern about brake dust.
Old Jul 26, 2014 | 11:17 AM
XJRS Owner's Avatar
Your parking brake isn't going to generate any dust, so it doesn't matter what you use.
Old Jul 26, 2014 | 02:54 PM
V12Vantage's Avatar
V12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura about
I don't think the parking brake is very efficient. Are there any replacement pads that might improve it.
Old Jul 26, 2014 | 07:42 PM
ArtB's Avatar
ArtB is a jewel in the roughArtB is a jewel in the roughArtB is a jewel in the rough
The parking brake is mechanical and only engages when you pull the emergency/parking brake lever up. During normal braking operation, the larger Brembo calipers do the braking, not the parking brake.
Old Jul 28, 2014 | 05:49 AM
rscultho's Avatar
rscultho is infamous around these parts
Those pads will work if you need to replace them, but as others have said they really don't generate any dust, unless you use your handbrake while you are driving!!!
Well I guess there are some maneuvers you use the handbrake for...
Old Jul 28, 2014 | 07:28 AM
i had read some where that
Dynamic stability control uses the parking
Brake?
Old Jul 28, 2014 | 07:32 AM
rscultho's Avatar
Brake?
Not on your DB9...
Newer models of Jaguar and other brands use the eBrake as an integral part of traction and stability control. But your DB9, and my DBS only connect the parking brake to the manual lever that engages/disengages the parking brake.
I don't know if the newer MY AM's use the ebrake in this way or not...
Rguy
Apr 12, 2020 11:11 PM
2lflat4
Nov 18, 2019 05:05 PM
plenum
Sep 2, 2015 09:16 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
