How To - '09 DB9 Battery Replacement
Old Nov 6, 2021 | 10:03 PM
otis74's Avatar
otis74 is infamous around these partsotis74 is infamous around these parts
Hi Jeff,
Thanks for responding and the Vanquish battery thread. Maybe I'm not pulling hard enough. I will give another try tomorrow.
Nick
Old Nov 6, 2021 | 10:20 PM
J doubleU's Avatar
There is a Torx 30 bolt at the outward back of the seat cushion that requires removing the seat cushion. Access via the seat back lower trim.
Old Nov 6, 2021 | 11:26 PM
otis74's Avatar
Appreciate the help. Thank you!
Old Nov 10, 2021 | 10:59 AM
nicholasdr's Avatar
nicholasdr is infamous around these parts
This is awesome, cheers Jeff.
I will add, I completed a battery swap a few months ago. I have a volante. I made the mistake of giving myself a brief panic by attempting to close the top (I figured working in the rear seat with the roof down would make it easier, and it did!). The roof however would only get about halfway before failing.
The reason? simple - I did not reset the windows... Once I reset the windows, the roof worked perfectly. In hindsight, the roof most likely won't operate until it knows where the windows are! I'm not the brightest perhaps.
Old Nov 10, 2021 | 12:10 PM
otis74's Avatar
Seat stuck
Thanks for sharing that! I just swapped out my battery on my 14 Vanquish and the passenger seat that I had moved all the way forward to access the battery would not slide back. I found a video on Youtube showing how to reset your
seats similar to a window reset. I reversed the incline all the way back and held for 2 seconds, and then all the way forward and held for 2 seconds and the seat worked fine. Good to know if my top has issues to first check the windows.
Nick
RBWIII
Dec 15, 2021 11:02 AM
telum01
May 16, 2021 11:15 PM
dicktahoe
Aug 7, 2018 04:21 PM
gircal
Jun 13, 2013 11:30 AM
lbredefe
Cayenne 955/957
Mar 17, 2011 03:01 PM
