2009 Dbs battery replacement?
Old Nov 4, 2014 | 01:27 PM
Robinls's Avatar
Robinls is infamous around these parts
Can't quite seem to figure out how to remove this battery. Can anyone help?
Old Nov 4, 2014 | 01:38 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Old Nov 4, 2014 | 01:42 PM
Robinls's Avatar
Originally Posted by yvr
Yes, already did that on the wife's car. The bosses car is a DBS and very different. Thanks though.
Old Nov 4, 2014 | 02:16 PM
yvr's Avatar
yvr
Pretty sure the battery is in the same location. Is the DBS a 2+0 configuration with no back seats?
Old Nov 4, 2014 | 02:38 PM
telum01's Avatar
I assumed it would be in the same place, under the parcel shelf.
Old Nov 4, 2014 | 02:52 PM
karlfranz's Avatar
Believe it or not, Aston Martin actually recommends removing the RHS front (passenger) seat in order to remove and replace the battery
  1. Remove the right side front seat.
  2. Remove the right heelboard.
  3. Disconnect the negative battery cable. [Always disconnect the earth (- ve) terminal first.]
  4. Disconnect the positive battery cable.
  5. Remove the three screws that attach the heelboard bracket to the body and remove the bracket.
  6. Remove the two bolts that attach the battery clamp to the body and remove the clamp.
  7. Disconnect the battery vent pipe and remove the battery.
Old Nov 4, 2014 | 02:58 PM
telum01's Avatar
wow....
Old Nov 5, 2014 | 07:21 AM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
Your wife has both a DB9 and a DBS???? 1st world problems. Love it!
Tomp
Jan 5, 2021 11:59 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
007AMV8
Oct 19, 2015 09:55 PM
DSCOFF
Aug 23, 2015 01:22 PM
