Accidentally removed my interior..
Old Dec 31, 2014 | 01:21 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
So since I had to remove a few of the interior panels on my DB9 to get the headliner out for the custom work I wanted to do to it I thought it was a really good time to address a few of the other little interior details I've been meaning to take care of.
I wanted to install the LED interior bulbs that many of you have spoken pretty highly about. Also the back window in my car has had a few smudges on it way down on the bottom portion where the glass meets the parcel shelf and behind the brake light. Totally impossible to get your hands in there to clean. To really do this right the parcel shelf needs to be removed, which was fine because I have this annoying rattle going on back there I needed to look in to. While the headliner was out, it was a good time to hard wire in my radar detector as well...
Well, one thing led to another and before I knew it I had most of my cars leather interior pieces on my kitchen counter top being cleaned and conditioned. I was really able to do a good thorough job this way. Obviously way more so than trying to do it all in the car. I'm an unmarried guy so I can do this kinda thing in my kitchen without backlash. More work that has happened in there in a very long time I should add..
I removed the passenger front seat. This was super easy and I think I'm going to do it every time I need to clean the interior. Really made getting access to the back of the car WAY easier. I'm 6'2 and 220 pounds and climbing in the back seat to do anything is nearly impossible.
Just 4 bolts and 4 wiring harness plugs. First unbolt the seat then you can easily tilt it back to more easily get access to the plugs.
It was a good project that wasn't too difficult. I just took my time and things came apart pretty easy and went back together without any surprises. I did go ahead and order all new plastic panel fasteners though for reassembly. It seemed like once you pulled these loose they would never hold tight again.
Here are a couple pictures. I was hoping to post more but the forum is limiting me to just 6. Is that correct??
Name:	seat bolt 1.jpg
Old Dec 31, 2014 | 01:27 PM
A few more pictures..
ID:	410938   Click image for larger version
ID:	410939   Click image for larger version
ID:	410940   Click image for larger version
ID:	410941   Click image for larger version
Old Dec 31, 2014 | 01:37 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I've got a set of pictures just like that I got mine apart with the passenger seat in place, but it was really cramped in the back. Next time the seat comes out!
Made me smile to see the hand-written markings behind the panels in mine, and it looks like you have some too.
Old Dec 31, 2014 | 01:42 PM
Back together, looking and smelling like brand new.
Old Dec 31, 2014 | 01:49 PM
Definitely! That was really fun to see. Removing the seat was a game changer. Really allowed easy access. So easy, I'll do it every time. Plus it revealed some things that could never have been uncovered otherwise. Here is one of the treasures found under the passenger seat. Made me wonder what kind of monster the PO was!! I'd like to note that the ketchup package was unopened..
Old Dec 31, 2014 | 02:11 PM
yvr's Avatar
yvr
BTW -- where did you get the new plastic fasteners? Is there a part number? I've got a couple of weak ones.
Old Dec 31, 2014 | 02:20 PM
I ordered originally from my dealer then needed a few more so I actually went down to NAPA and found some that were nearly identical. Here is one of the part numbers from Aston Martin. I ran into 3 different ones. Depending on what part I was working on. The dealer can easily look it up for you if you describe the part you're trying to secure
Old Dec 31, 2014 | 02:46 PM
yvr's Avatar
yvr
Awesome. Thanks!
Old Dec 31, 2014 | 02:48 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Lightbulb
Thanks for posting speedracer800. That seat is coming out of mine next time the leatherique goes on! I debated doing so when replacing the battery. I really shouda !!
Old Dec 31, 2014 | 03:23 PM
The key is to tilt the seat all the way forward before unhooking the electronics. Makes it a smaller package coming out the opening. Also helps to have a second person help guide it out. It's not too heavy, easily a one man job but I worried about nicking the inner door panel, etc when removing it. I also covered the sill plates for the same reason.. Good luck.
Old Dec 31, 2014 | 07:05 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Brilliant and familiar pictures I see. Thanks for posting the part-number for the black pushers; will need a bag of these as well when I put the interior back eventually.
ID:	410965   Click image for larger version
Old Dec 31, 2014 | 07:28 PM
telum01's Avatar
I'm gonna need more pics of your seat setup, and how it's mounted
Old Jan 1, 2015 | 12:53 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
why does a guy who is mostly single want a car with a back seat Aston martin a single guy...im jealous
thanks for sharing the pics
Old May 15, 2015 | 02:04 AM
wysoseereeus's Avatar
wysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nice
Attachment 410948
Impressive work. How long did it take you pull everything apart and put things back together again? And did you use the Workshop Manual to help you figure things out?
Old May 16, 2015 | 12:28 AM
Actually not very long. 4-5 hours tops. I didn't have a shop manual, I just figured it out as I went with the help of posts on this forum. It's really very straightforward.
