Preowned warranty
Preowned warranty
Hi as you guys know I have a 2007 Vantage I bought in August with the one year extended Aston Martin warranty. I just discovered that one of my rear shocks and rubber brake lines are leaking at the back of the car. It could also be the rear caliper I'll have to check more closely. Does anyone know if those items are covered. I'm aware that trim items are not covered thank you
Ron
Ron
If it's an Aston extended, then the shock should be covered if it's leaking, leaking is not "wear"..also, they are to be replaced in axle sets, but extended warranty will not pay for the other damper, that would be at the owners cost
The brakes lines are actually stainless steel..I've yet to see one leak but does not at all mean it's not possible
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
As far as the brake line goes, it could be the caliper it's hard to tell I didn't want to clean it because I want to the dealer to see the fluid on the brake line which looks like rubber in my car
Ron
If it was a regular warranty, yes the other damper in that axle would be paid for by warranty if a particular mileage is meet.. But extended warranty doesn't have the same beliefs..
My info, ummm.. I've been around :-P
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
You may want to read this thread to get some insight as to Irish07's Knowledge on AMs
https://www.6speedonline.com/forums/...-irish007.html
Ron
Okay I just had the car in to Galpin yesterday. They said the left rear shock is leaking and they will replace it under the extended warranty. The odd thing is they replace both rear shocks before I purchase the car last summer and said they've never seen a new shock go bad so quickly. The oil leak on the right rear was not that shock but the overflow for the transaxle which was overfilled and spraying oil on my right rear wheel and bumper! So they drained some oil out of the transaxle to the proper level clean the oil up and we'll see what happens.
Ron
Ron
jaehoppa
Oct 22, 2015 09:17 PM
Vrrooom
Sep 15, 2015 02:03 PM
