Bulb failure dipped beam
Old Feb 14, 2015 | 03:59 PM
Aston502's Avatar
Aston502 is infamous around these parts
The manual says take to your dealer. Is this something we can handle? Thanks guys
Old Feb 15, 2015 | 01:43 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
Very easy fix. The bulb is a common part that can be had for about $40. Look in your manual for the exact type. You can search this forum and find quite a few extensive DIY threads regarding replacing that bulb. Basically you need to remove the front wheel and on the inside of the inner fender liner, directly behind the fixture in question there's a plastic access panel. Behind that panel is the back of the light fixture. Pop off the rubber caps to gain access to the inside and then it's pretty straight forward. Hope that helps.. Good luck.
Old Feb 16, 2015 | 12:08 PM
Aston502's Avatar
Thanks very much for the help
Will give that a look when I can.
vogz
Oct 8, 2015 12:02 PM
ECS Tuning - BMW
Sep 30, 2015 12:40 PM
ECS Tuning - BMW
Sep 30, 2015 12:27 PM
ECS Tuning - BMW
Sep 29, 2015 01:18 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
