Power steering v8 vantage
Wondering if anyone call help? i want to replace the power steering fluid in my car the official AM factory manual does not give the quantity it does mention capacities for all other fluids but not this?
Second question will standard red ATF be sufficient for the pump pressure at 116? or is is a special fluid.
Don't use ATF unless you have to. Get a tin of the updated Pentosin green fluid that every newer European car uses. And you may want to add some squeaky snake oil. Jaguar dealer should have both.
Thanks for the reply but the bottle in the engine bay says ATF oil only? any ideas on the quantity? it will take when its empty?
So, I understand most are switching to the CF11, which I think Is an ATF fluid too, but Ive also heard that folks are using STC50519 which ive found to be a cross.. . its the range rover standard for PS steering fluid as well. (also atf)
true? I have a V8 vantage 2006
