07 V8V: Oil Change
Old Mar 18, 2015 | 07:07 AM
jcpca356's Avatar
jcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to beholdjcpca356 is a splendid one to behold
07 V8V: Oil Change
Where is your go to place to get oil filters and necessary parts? (other than the dealer of course) It's been over a year and a half
Old Mar 18, 2015 | 07:21 AM
jcpca356's Avatar
Old Mar 18, 2015 | 08:24 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
It's covered in detail in the "Frequently Asked Questions" posting:
https://www.6speedonline.com/forums/...il-change.html
Old Mar 18, 2015 | 09:37 AM
jcpca356's Avatar
thanks!
Old Mar 19, 2015 | 09:09 AM
rohnin's Avatar
rohnin is infamous around these parts
Just lazy to look it up but what is the mileage interval for changing the oil?
Old Mar 19, 2015 | 11:14 AM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
10k miles or once a year. Sooner if driving in off-road / dusty conditions.
Old Mar 19, 2015 | 11:31 AM
rohnin's Avatar
Thanks, I was worried as my friend told me every 3000 miles lol
Old Mar 19, 2015 | 12:49 PM
lovingit's Avatar
lovingit is infamous around these parts
Technically, if you drive under 10k miles a year, do you still have to take it in? Say you drive 5k or less a year.
Old Mar 19, 2015 | 02:11 PM
karlfranz's Avatar
^^^ Yes.
Old Mar 19, 2015 | 02:50 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
I see on the oil change we remove the two metal mesh filters as part of the job replace the o ring and once clean refit?
I took mine out, they were clean, (eaten in dirtier restaurants in Africa)
I got in the Oil Change kit from AM a bolt that goes into the engine further back and has a rubber sealing ring as well as a new copper washer is it nesassary to pull that when you have removed the old oil as well as cleaned mesh filters and replaced the oil filter?
Then if anyone who know's?? (Telum? Karl?) say one drives only 3000 Miles per year and you pull the oil is there merit in replacing the oil filter? considering that some guys do almost or even more than 10 000 miles per year on the same filter?
Old Mar 19, 2015 | 03:26 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Try these threads . info on other makes of oil filter etc .
https://www.6speedonline.com/forums/...n-filters.html
My Vantage had a Bosch filter on it when I did the oil change . It now has a Fram and I have a AM filter on the shelf for next time . Seeing As I will only be doing limited fair weather driving I will just be using the Fram filters once the AM filter is used . I will be changing the oil yearly but I may try the Redline oil next year as its so much cheaper than the Castrol Liquid Gold .
FWIW I can buy a 5 gal pail of Redline for the same price as the required quantity of 1 oil change of Castrol Liquid Gold .
Old Mar 19, 2015 | 06:05 PM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
I sure hope no one is off-road with these gorgeous cars.
Old Mar 19, 2015 | 06:44 PM
OTS's Avatar
OTS
OTS is infamous around these parts
^^ I do it in my* rally spec GT4. http://blackflag.jalopnik.com/maniac...car-1681820324
*Disclaimer: I do not have a rally spec GT4.
Old Mar 19, 2015 | 08:16 PM
Batman-76's Avatar
That would be Awesome!!
Forget track days, I want a go in the rally car
Old Mar 20, 2015 | 07:31 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
I go with what the manufacturer recommends. I think the main reason to change oil is because the additives get depleted. Now with that said, some manufacturers, such as Porsche, RECOMMEND, changing the filter at every other Oil Change, and on the Boxster the change is 15,000 miles/every year.
