I just did my annual service...myself
Old Aug 6, 2015 | 01:31 PM
telum01's Avatar
Originally Posted by fbiguy
Thanks for the write up. I am going to do my own maintenance this time around. I bought a 2 ton low profile jack that will get under even a lowered car. I also have a pair of 3 ton stands since I won't get under a car that's only being held up by the little o ring in the jack. Before I bash it (since it's from Harbour Freight), it has done great lifting the front of my 3 ton Range Rover and the front of my old El Camino, with a full iron 454.
You should get a second pair of jack stands so you have the car lifted at four corners. Far safer that way!
Old Aug 6, 2015 | 03:17 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Even safer ...... Drive on hoist and be done with it .
Old Nov 17, 2015 | 02:54 PM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
I have a mobile mechanic that i use for my various cars. Your post is really inspiring me to get all the parts and have him do the service on my aston! I think lift would be necessary for the air filter.
Old Nov 17, 2015 | 03:00 PM
911MTB's Avatar
911MTB is infamous around these parts
I'm glad I inspired you I think you could have your mobile mechanic do the service. I did the air filters without a lift and didn't find it very difficult. I have since purchased RaceRamps from Amazon which will make it even easier to get under the car for this service. Cheers!
Old Nov 17, 2015 | 03:20 PM
goto35's Avatar
Did you just get 2 raceramps? Also what size did you get? I may invest on the raceramps as well
Old Nov 17, 2015 | 08:07 PM
little nellie's Avatar
little nellie is infamous around these parts
I remember seeing a drive on ramp that has a built-in hydraulic jack. Once you drive on to it, you can jack it up even higher. Don't remember where I seen this and unable to find it again. I would think this will be a great way to lift the car up to be work on. Anyone seen these before?
Old Nov 17, 2015 | 08:11 PM
Vantagelvr's Avatar
That's exactly what I have on my hoist . It's called a bridge jack . It slides on rails between the drive Ramps so you can jack the car up anywhere suitable and it has wings that extend out sideways to reach the jack points . It's awesome for working on all my cars . Wish I bought it years ago .
Old Nov 17, 2015 | 08:50 PM
Not the bridge jack.. the one I am thinking of, you actually drives on to a ramp. Once on the ramp, the ramp can be raise with hydraulic pistons.
Old Nov 17, 2015 | 09:03 PM
I found it.. I hope I can post the link to what I was thinking about..
http://www.cjautos.eu/product_p/cr01.htm
Old Nov 18, 2015 | 12:43 PM
911MTB's Avatar
I got the two-piece 56" Race ramps. They fit under the front of the car without rubbing.
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
drcollie
Oct 2, 2015 09:34 PM
