Stone guards
Old Nov 17, 2015 | 07:06 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Stone guards
I just picked up a 2009 V8V and would like to put the stone guards on it. Where is the best place to get them? I'm about a hundred and fifty miles away from the closest dealer.
Thanks for the help.
Old Nov 18, 2015 | 09:12 AM
corveight's Avatar
corveight is infamous around these parts
I purchased mine from Astonmartincarparts.com. Quick install and I think with shipping under $100. Although I have a DB9 They have little effect in my opinion. The sills and quarters after 8 months and 12000 of driving need to be refinished.
Old Nov 18, 2015 | 05:25 PM
Gene G's Avatar
Thanks for the info corveight. I sent them a message to get a quote.
Ordered them today.
Old Mar 25, 2016 | 09:32 AM
Gene G's Avatar
Does anyone know if stone guards are available for the rear fenders like the ones for the front fenders? I put the DBS wheels on the Vantage and the tires now sit flush with the wheel well. Would like to have something behind the rear wheel to help protect the rear fender and bumper.
Old Mar 25, 2016 | 11:18 AM
XJRS Owner's Avatar
None
Old Mar 25, 2016 | 01:23 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
I bought mine from Aston Martin bits. About the same price $100 or so. I had the dealer install them. The best way to protect the side of the car is a clear bra on the sills, and in the front of the rear fenders just behind the door's. I bought my car used with 2800 miles. I had the clear bra installed on the hood and the front bumper but did not do the sides and in the front of the rear fenders. After a trip to Monterey and back they were already pitted. Then I had the clear bra installed on the sills and in front of the rear fenders wished I had done it first .
Ron
Old Mar 25, 2016 | 03:40 PM
impulsiv's Avatar
impulsiv is a jewel in the roughimpulsiv is a jewel in the roughimpulsiv is a jewel in the rough
I would like to see a picture of the part you're talking about. Are you referring to a mudflap? or clear film?
Old Mar 25, 2016 | 07:52 PM
XJRS Owner's Avatar
Stone guards = mud flaps
Fronts only, no rears.
Old Dec 15, 2017 | 04:44 PM
MRCW's Avatar
Hi Gene... I just got them also. Since I have 20" wheels that are a bit out of the fenders, i thought they would help cut down on dirt rocks, etc. Did you install? I ordered some of the plastic rivets and it seems like there is one screw.
Looks simple enough to install. I hope i get used to the look, because the smooth rounded sills look great.
Old Dec 15, 2017 | 04:51 PM
Gene G's Avatar
I did install them when I had the black 09. But they were already on my green car. Very simple installation. They do help quite a bit as I have no stone chips on the green car.
Old Dec 15, 2017 | 05:06 PM
MRCW's Avatar
Originally Posted by Redpants
Not much to them:
Do you know if new holes need to be drilled or do they use existing holes?
Old Dec 15, 2017 | 05:12 PM
Gene G's Avatar
No drilling needed they use existing holes.
Old Dec 16, 2017 | 01:45 PM
MRCW's Avatar
Thanks! Put them on... about 10 minutes each side, after I had to get longer screws!
Old May 22, 2021 | 08:44 PM
Gene G's Avatar
Does anyone know if they will fit on a Vantage with the V12 style rocker panels?
Old May 23, 2021 | 06:18 AM
MRCW's Avatar
hi gene, FWIW here are some pics of my stone guards. I think they should work because the fit at the wheel well is pretty snug... before the rocker skirt flares out... you may also want to check Scuderia to see if the part number for them is the same
