How much oil does your V8V burn
Castrol 5w-50 works much better in my opinion and makes the engine feel more free revving as well. It's a good year round oil you can year in both summer and winter without any negative consequences. BMW also recommends this oil on their 10w-60 cars so it should not be an issues.
The oil gets changed the screens are pulled and the the oil thermostat get removed so I get as much of the oil drained as possible . I have a hoist so it's no problem for me . I always change the filter what's the point in changing the oil if you don't change the filter ?
When I got the car it had a Bosch oil filter on it , that crossed to a Fram PH 9010 so I used that . I did get an Aston Filter cheap on flea bay so I just used that but I will go back to the Bosch or Fram or K&N whatever I can get locally . It's just a filter so I'm not paying 50$ just to get an Aston part# painted on a K&N or whoevers filter it is and seeing as it gets changed way more frequently than actually required I'm not concerned .
As for changing a filter at 2000km I'm not sure there is benefit, that is why I ask, in the piston helicopters we replace oil at 50 hours, and we get a full oil analysis done, I read these (and understand) what it says, in my Aston it's normally too new to make decisions as I run very little mileage between oil changes.
Would love to get Oem technical advise on filter replacement annually from a cut open and Annalise point of view, it's not about the saving .....just is it worth it at 2000km per year? And I feel filter replacement every two years is ok?
I get my filters mailed from AM of New England in Waltham for $38 including washers.
58k miles and burning about half a quart every 1500 miles. Average driving.
Based on my oil change frequency the chances of the bypass valve/spring working to early are probably slim to none .
Oh, just to clarify, if the warning light comes on, your oil level is really low... it's a red triangle (not orange) for a reason. Definitely check your dipstick. Takes only a minute.
True story ... I'm at the parts counter at the local BMW dealership waiting to get parts for my good lady's Z4 ... Guy in front of me asks for windshield fluid ...... Counter guy says yes sir it's right there grab what you need ..... Customer "it's not BMW fluid ....won't that affect my warranty?"
.......True story I kid you not !!!!!!
Probably the same guy that books it in to the dealership to have the ash tray emptied and get that special BMW air put in the tires !!!
michael_l
Dec 29, 2015 07:48 AM
hollynitro
Dec 2, 2015 07:24 PM
Nandor Orban
Cayenne 958
Nov 28, 2015 08:23 AM
