DB9 power sockets (aka Cigarette light) will not work with USB adapter
Old Dec 21, 2015 | 04:18 PM
ajmevans's Avatar
ajmevans is infamous around these parts
This one has me puzzled both the outlets in the cabin and trunk will not work with one of those USB adapter plugs (which work fine in my other cars), odd thing is if you use it as intended the lighter heater element works...so fuses are OK, any one got an idea or cure for this...nice to be able to charge iPhone on long trips. I have tried ignition on and off, nada!
Old Dec 21, 2015 | 06:16 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
If the lighter-element works it means its primed. I suspect the iphone-charger. Try to measure voltage with a multimeter to rule things out.
I had once this little Chinese 2-USB pop-in charger which didn't work either when not pressed-in hard.
HotRodGuy
Apr 6, 2017 07:30 AM
RDH
Florida
Jan 24, 2016 05:59 AM
Ion
Dec 9, 2015 09:29 AM
ECS Tuning - BMW
Dec 3, 2015 11:52 AM
