2007 DB9 First gear vibration
Old Dec 28, 2015 | 06:53 PM
BraBiz's Avatar
BraBiz is infamous around these parts
Have auto box. When cold, car has power train vibration from take off. Once car warms up, seems to go away. Any suggestions as to what's going on?
Old Jan 24, 2016 | 03:07 PM
Organeer's Avatar
Organeer is infamous around these parts
Is that going in a straight line or turning a corner?
If it is on turning it could be the diff fluid needing a change with limited slip oil.
Old Jan 25, 2016 | 09:28 AM
BraBiz's Avatar
Thank you for your response. It is only when turning corners at low speed and full lock. I'll get it looked at.
Old Feb 1, 2016 | 06:30 PM
BraBiz's Avatar
Changed the diff oil today and problem solved. Mechanic said the old oil was burnt and very low. Completely drained it and replaced with new synthetic oil. The vibration is gone. Thank you for your guidance. Saved me time and money.
88carrera
Feb 2, 2016 10:45 PM
DrJ991turbos
Jan 28, 2016 04:39 PM
onefastman1
Bentley
Jan 8, 2016 04:26 PM
viprklr
Dec 25, 2015 06:57 PM
