Any available to walk me through jacking my 2007 am v8v
Old Jan 16, 2016 | 12:37 PM
alexhuth's Avatar
alexhuth is infamous around these parts
I guys I'm a little chicken **** when it comes to this I jacked it up on one side but unsure where to place the jack stands any one want to help out?
Old Jan 16, 2016 | 12:39 PM
alexhuth's Avatar
I see on telums brake video that his stands are where my jack is? Did he use that center area to jack it up?
Old Jan 16, 2016 | 12:44 PM
alexhuth's Avatar
Also I'm contemplating just doing the work with just the jack under it. Any one want to tell me how stupid I am. I'm replacing the door struts.
Old Jan 16, 2016 | 01:35 PM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
Here's a thread from LotusTalk.com that shows a good (if a bit fussy) way to get the car on jack stands located at the jacking points. Starting with post #68 - http://www.lotustalk.com/forums/f170...66/index4.html
However you do need two floor jacks with this method.
Old Jan 16, 2016 | 03:20 PM
embdenb's Avatar
My understanding is that the jacking points (sill cutouts behind the front wheel and just in front of the rear wheels) expose a beam that actually continues past the front jacking point. It appears that you can position a floor jack approximately 12 inches or so rearward of the front jacking point, which leaves room to position a jack stand at the front jacking point.
Old Jan 16, 2016 | 04:08 PM
alexhuth's Avatar
I ended up just using a piston jack. Jacked it up with a floor jack and then put a piston jack under and used that. There was enough space for both on the front jack point shown in the manual.
Old Jan 16, 2016 | 04:47 PM
Montana107's Avatar
Montana107 is infamous around these parts
I jack from the front jack point, use jack stands with rubber pads and set the jack stands in the following positions.
Old Jun 7, 2024 | 12:14 PM
pierremanu's Avatar
pierremanu
there is no rubber on the oher side of hsm pucks?
tadaslyra
Bentley
Aug 17, 2024 10:41 AM
baron
Jan 22, 2018 04:13 PM
ECS Tuning - BMW
Jan 12, 2016 01:58 PM
alexhuth
Jan 11, 2016 08:37 PM
