Can someone tell me what this is?
Old Mar 2, 2016 | 07:21 PM
jerhofer's Avatar
jerhofer is just really nicejerhofer is just really nicejerhofer is just really nicejerhofer is just really nice
While preparing to remove the fenderwell liners, I found a nut lying on the lower control arm and a link that was not hooked up. This link is only on the driver's side. What does it do?
Old Mar 2, 2016 | 07:33 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Headlight leveling sensor
Presuming that you have the HID option...
Name:	V8 Vantage 2006MY Workshop Manual 329.jpg
Old Mar 2, 2016 | 07:57 PM
telum01's Avatar
What DonL said. It's for the headlight leveling system.
Old Mar 2, 2016 | 07:59 PM
jerhofer's Avatar
Thanks. I will have to check out the hardware in the rear to make sure it is connected.
Old Mar 3, 2016 | 05:07 PM
ab_aston's Avatar
ab_aston is a glorious beacon of lightab_aston is a glorious beacon of lightab_aston is a glorious beacon of lightab_aston is a glorious beacon of lightab_aston is a glorious beacon of light
I had the same thing the first time I took my wheels off. Although in my case, the nut was had tightened on the bolt, just not connected to the arm. My rear one was connected. I can only guess that it was undone for some sort of work and then forgotten to be put back. Perhaps the same happened to yours, but your nut/bolt came undone?
Old Mar 3, 2016 | 07:40 PM
jerhofer's Avatar
There was no bolt. Only the nut.
JohnAMG
Mar 1, 2016 12:45 PM
terminal_ac
Feb 26, 2016 03:37 PM
