Plasti dip rims?
Old Mar 11, 2016 | 10:16 AM
alexhuth's Avatar
alexhuth is infamous around these parts
Plasti dip rims?
Has anyone gone the extra cheap route of plasti dipping your rims? I am thinking of making mine gloss black?
Any thoughts experiences? I also am thinking of doing the grill as well.
Old Mar 11, 2016 | 11:24 AM
telum01's Avatar
The grille will chip and peel because of where it's located.
I've seen wheels come out nicely, but not sure how long it lasts.
Old Mar 11, 2016 | 11:26 AM
embdenb's Avatar
Not sure of the cost, but powder coating is a much better option
Old Mar 11, 2016 | 11:37 AM
telum01's Avatar
Powder coating is far better, but Plastidip is very cheap and generally reversible (be careful where you get it lol)
Old Mar 11, 2016 | 11:39 AM
alexhuth's Avatar
Exactly! I don't want it to be perm so I think this would be best for me.
Old Mar 11, 2016 | 03:29 PM
sam i am's Avatar
sam i am is infamous around these parts
I dipped the grille of my Wrangler four months ago, it seems to be holding up fine, with probably more abuse than your grille will encounter.
Old Mar 11, 2016 | 06:44 PM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
I dipped my track-car wheels and they are still perfect after 6 track weekends and 1000+ track miles.
Old Mar 11, 2016 | 06:50 PM
impulsiv's Avatar
impulsiv is a jewel in the roughimpulsiv is a jewel in the roughimpulsiv is a jewel in the rough
Plasti-dip + Glossifier suck. You won't get a nice smooth finish. At least not from a can.
Old Mar 11, 2016 | 08:46 PM
Teekster's Avatar
Teekster is infamous around these partsTeekster is infamous around these parts
I dipped my wife's LR4 winter wheels 2 years ago and they are holding up fine. I dipped my 996 winter wheels and used glossifier this year. Not thrilled with that result. Not sure either finish would look right on an Aston.
Old Mar 11, 2016 | 08:50 PM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
Currently 'dipping' some under bonnet parts to see how they look before committing to powder coating. Like being able to peel it off.
Old Mar 11, 2016 | 09:42 PM
alexhuth's Avatar
Sounds like a lot of positive feedback!
Old Mar 11, 2016 | 09:51 PM
Jeff_335i's Avatar
The only thing is that I don't think that the "gloss" finish looks good at all. The matte black looks smooth and uniform, all the attempts I've seen at gloss look bad.
Old Mar 11, 2016 | 10:20 PM
alexhuth's Avatar
I will do matte black first and if I don't like it I will do another layer and do the gloss and if I don't like that I will rip it all off!
Thanks for the input!
Old Mar 11, 2016 | 10:37 PM
alexhuth's Avatar
This is ArtB car on the bottom and mine on the top. I'm certainly thinking about this look long and hard! But with plasti dip I don't have to commit to anything.
Old Mar 12, 2016 | 10:20 AM
Jeff_335i's Avatar
I say go for it! It only takes some time and about $45 of plastidip and if you don't like it, peel it off.
Don't forget you also need to do the back side of the wheels, and the inside of the wheel barrels. Otherwise it will look funny. I used 7 spray cans of dip to do 4 wheels. Be sure to make the coating thick enough, otherwise it is harder to remove. When you spray it on, as long as you don't have any runs the coating will dry smooth. If you get a run, wipe it off right away with some paper towel and re-spray the surface. I was amazed at how crappy it can look while it's wet and still dry very smooth.
I used 3x5 index cards slipped in between the tire and the rim to mask off the tire from the wheel. That worked perfectly, and much easier than trying to use masking tape.
