HELP! Trunk wont open...
Old Mar 24, 2016 | 10:03 AM
meteoritesilver's Avatar
meteoritesilver
If someone out there has experience with this problem, I could really use advice on how to "fix" the problem . My trunk will not open not only from the little silver nipple on the lid itself, but also from inside the cabin on that little switch near the shifter and also from the remote key fob. What do you think? Thanks
Old Mar 24, 2016 | 10:21 AM
telum01's Avatar
If you're limber....
Reach behind the back seats and release the strings on the cargo divider (the one that hold the cargo divider up when opening the trunk)
Pull the release tab on the cargo divider. The cargo divider will drop down into the trunk.
Crawl on in there and reach for the emergency release handle, it's near the back on the underside of the trunk lid.
That's a mechanical release for the trunk so the trunk should pop right open.
Old Mar 24, 2016 | 10:24 AM
meteoritesilver
Thanks. Did that and you certainly need to be limber
But at this point I need to know why it's not working....Thanks!!
Old Mar 24, 2016 | 02:11 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Did you try hitting the unlock button on the center console prior to operating the trunk release buttons? Sometimes it helps to toggle it back and forth, then hit trunk release.
Old Mar 24, 2016 | 03:17 PM
J doubleU's Avatar
Do the door locks operate? Does the glove box open? Anything done prior to this fault.
Old Mar 28, 2016 | 03:46 PM
Organeer's Avatar
Organeer is infamous around these parts
Probably the solenoid in the boot latch. I have just fitted a new latch due to the little switch not operating correctly which lit up the dashboard "Boot Open" light.
It also affected the car locking system.
The latch is not expensive and is relatively easy to replace. It is a good idea to mark the position of the old latch as a guide to fitting the new one as there is quite a bit of adjustment available.
The latch is a Volvo part BTW.
Old Apr 22, 2016 | 05:42 PM
meteoritesilver
The glove box opens. The door locks work as well. However, the glove box did blow a fuse around the same time that the hatch stopped working. But I simply change the fuse and the glove box is fine. Thanks.
meteoritesilver
Originally Posted by Organeer
Probably the solenoid in the boot latch. I have just fitted a new latch due to the little switch not operating correctly which lit up the dashboard "Boot Open" light. It also affected the car locking system. The latch is not expensive and is relatively easy to replace. It is a good idea to mark the position of the old latch as a guide to fitting the new one as there is quite a bit of adjustment available. The latch is a Volvo part BTW.
Thanks. Do you know where I could buy this solenoid?
Old Apr 23, 2016 | 03:10 AM
Organeer's Avatar
Buy the whole boot latch. It doesn't come apart easily as it is riveted together and the rivet shafts form part of the spacer mechanism of the lock. Because the whole thing is so cheap it would be easier to just buy it complete. From memory the solenoid is made by Hella.
Old Apr 23, 2016 | 07:10 AM
meteoritesilver
Thanks very much. On it
Old Apr 23, 2016 | 07:32 AM
Scotty4300's Avatar
Scotty4300 is infamous around these parts
Hi Telum01,
I mostly open the boot (trunk) on my 2008 Vantage to plug in my c-tek conditioner.
I pulled the safety release just out of interest (how could you ever get shut in?) and being cheap plastic it fell apart.
Being a woodworker I think I will make a new toggle in rosewood.
Old Apr 23, 2016 | 08:10 AM
telum01's Avatar
Originally Posted by Scotty4300
Hi Telum01,
"There's tons of space in the trunk. I'm pretty sure I could fit back there."
"Prove it"
Haven't seen one of the emergency release handles crumble before - that's pretty impressive lol. The rosewood would be really interesting, only concern would be that it wouldn't be glow-in-the-dark like the original (it glows for safety/visibility in the dark). Probably not a concern for most people or most situations hahaha
Old Apr 23, 2016 | 10:51 PM
Scotty4300's Avatar
Thats OK in your coupe--mine is a roadster!
bdschet
Jul 24, 2016 06:24 PM
997.1TT
Apr 11, 2016 06:40 PM
acs370
Mar 30, 2016 08:26 AM
vettegood
Bentley
Mar 23, 2016 05:10 PM
GTstreet996
Mar 22, 2016 09:14 PM
