Just finished a 3 day paint correction
Old Apr 7, 2016 | 09:52 AM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
11 years old 8 thousand miles and still never been in the rain.
Old Apr 7, 2016 | 10:06 AM
Gene G's Avatar
Doesn't have as big or as many metallic chips in the paint but the paint is much harder.
Old Apr 7, 2016 | 10:57 AM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
That must be quite a feat in Florida!
Old Apr 7, 2016 | 11:29 AM
Gene G's Avatar
Sometimes the weather is frustrating but that is what the Tiguan is for.
Old Apr 7, 2016 | 04:24 PM
Jeff_335i's Avatar
Talk about frustrating weather, it's snowing in WI today...
Old Apr 7, 2016 | 04:49 PM
Gene G's Avatar
I feel for you. I grew up in Norther Illinois and spent a lot of time in Wisconsin.
The winters are tough but what a beautiful place.
Old Apr 11, 2016 | 05:01 PM
Jeff_335i's Avatar
Gene, did you remove your rotors to paint the hubs or did you paint them on the car?
Old Apr 11, 2016 | 05:34 PM
Gene G's Avatar
I painted them on the car using a foam brush and high temperature silver paint.
Old Apr 11, 2016 | 06:48 PM
Jeff_335i's Avatar
Did you use spray paint and brush it on or did you have the paint in a can?
Old Apr 11, 2016 | 07:02 PM
Gene G's Avatar
I used silver high temp spray paint. I sprayed it into a small plastic tray and then used a disposable foam brush from Ace hardware.
Old Apr 11, 2016 | 07:10 PM
Jeff_335i's Avatar
Thanks for the info.
Old Apr 11, 2016 | 07:18 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
What did you use for a clear coat on top of the paint?????? Did the foam stick leave any telltale lines or strokes?
Anywhere near Tampa????
Old Apr 12, 2016 | 07:06 AM
Gene G's Avatar
I used nothing on top of the high temp paint. The foam brush didn't leave any marks. That is why I used a foam brush instead of a normal paint brush.
Old Apr 12, 2016 | 09:28 AM
Jeff_335i's Avatar
Gene, do you happen to have any pictures of how the rotors turned out?
Old Apr 12, 2016 | 10:09 AM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
I'm interested on how the rotors turned out as well. Mine look bad and trying to figure out how to make them look good again.
