Vantage suspension squeak
Old Apr 5, 2016 | 12:01 PM
deckman's Avatar
Today I noticed pretty loud squeaking from my suspension just driving on the road. More so when hitting bumps. Can't say I've noticed it before. I think it's coming from the front. Has anyone had this? It's a 9k miles 2013 6MT. Thanks.
Old Apr 7, 2016 | 09:52 AM
MadeInPorshe's Avatar
MadeInPorshe is infamous around these partsMadeInPorshe is infamous around these parts
I had the same issue on my 2011 with 8k miles which sounded like a rubber duck rolling through the underground. Not sure if it's the same issue but I jacked up the car with the tire fully off the ground and it went away upon lowering. This was completely by fluke that it worked as I was swapping rims.
Old Apr 7, 2016 | 07:57 PM
deckman's Avatar
That is odd.
Old Apr 8, 2016 | 09:38 AM
SinisterSF's Avatar
5 Year Member
SinisterSF is infamous around these parts
Sounds like you've got an unhappy bushing or strut. Has the car gotten very dirty? Could have some muck in a tight spot. I'd get it up in the air and put a jack under a tire to get some up and down action to try and locate the actual squeak.
Old Apr 13, 2016 | 06:17 PM
deckman's Avatar
That's a good idea I'll do that.
Old May 14, 2016 | 11:06 AM
deckman's Avatar
I'm finally going to look at this on Sunday. I kind of doubt I'll see anything visually that identifies the problem. I hope it's something simple. It's embarrassing, it makes the noise over every little bump, mostly noticeable after I've driven the car for at least 5-10 minutes. It almost sounds like a squeaky bed.
Old May 29, 2020 | 02:30 AM
talltim's Avatar
talltim is infamous around these parts
Hi
Apologies for the thread resurrection
What was the resolution to your noisy front suspension?
Old May 29, 2020 | 08:00 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
I have the same thing, its either the sway bar bushings or the upper control arm bushings
I've been lazy and haven't done any work on the car but maybe sometime this weekend i'll check it out
edit: lol didn't notice this was from 2016
Old Jun 1, 2020 | 04:45 AM
thisistcab7's Avatar
thisistcab7 is infamous around these parts
This happens to me, but only on very cold days and until the car warms up
Old Jun 1, 2020 | 11:58 AM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
Suspension Squeak/Noise
Hey Guys:
Regarding the suspension noise/squeak:
I've have had a similar noise/squeak in my suspension for years now and I been after my franchised Aston dealer to locate/determine the source of it (to no-avail)... mine's at the rear of the car. I finally found this post of the same noise but coming from the front suspension of a DB9...
I hope this helps.
https://aston1936.com/2018/08/11/rep...on-martin-db9/
The noise was discovered/noted whilst the car was under warranty, however I have little faith that Aston will step up and pay for the repair (along with a couple of paint bubbling issues). Sadly, Aston has no money to keep this customer happy...
Cheers, Dan Murphy aka axarunner
Old Jun 1, 2020 | 02:11 PM
steve36's Avatar
steve36 is infamous around these parts
Originally Posted by AXARUNNER
Hey Guys:
I hope this helps.
I had the same thing on my 2012 Virage. Actually had it twice.
First time replaced all the upper control arms as the bushings were gone but you can not buy bushings separately.
Second time it was noticed that a part of the body (under carriage) was rubbing on another part of the body. A mild bend fixed it.
Old Jun 1, 2020 | 02:31 PM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
About a year ago I experienced a creaking sound when backing out of my driveway...it was minor and I didn't think much of it., did not even mention it when I took my car in for annual maintenance.
My dealer did notice and replaced both front and rear control arms under the extended warranty...noise gone.
Thanks,
JH
Old Jun 1, 2020 | 03:03 PM
AXARUNNER's Avatar
Both Miller Motor Cars in Greenwich, CT and Aston Martin Summit, NJ completely miss-diagnosed this (seemingly common) problem. To say I'm disappointed is an understatement. I love the brand, I hate the customer service.
Old Jun 1, 2020 | 08:50 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I replaced my front upper control arms per aston1936 and the squeaks disappeared. Then I started getting some squeaks from the rear when the weather was cool.
An Aston tech revealed that he uses a a silicone grease to keep the squeaks away. I applied it to the rear upper bushings and it's been quiet ever since:
OEM Honda Shin-etsu Silicone Grease 100g 08798-9013
Old Jun 2, 2020 | 10:34 AM
talltim's Avatar
Thanks guys
Looks like Upper control arms are a common denominator
My noise only starts after driving for about 15 minutes and would appear to be the right hand front
Its booked in next week so will point them in that direction
