Brake flush when?
Old Apr 29, 2016 | 06:16 AM
embdenb's Avatar
Brake flush when?
Just got a service alert on the wife's Mercedes that indicates, among other things, a brake fluid flush. The car is 4 years old and just under 40k miles.
That led me to thinking, is this really necessary at 40K, and at what interval does Aston Martin recommend a brake fluid flush.
My Honda recommended a brake fluid flush at 100K if I remember correctly. I understand that moisture will eventually contaminate the fluid, but modern cars brake systems are pretty air tight. I can go along with flushing the brake system every 5 years and or 50K miles, but I am not convinced that this should be done every 2 years as recommended on the MB discussion list.
Any thoughts on this ?
Old Apr 29, 2016 | 06:40 AM
telum01's Avatar
Aston's service interval for brake fluid is every 2 years/20k miles.
I think for a normally-driven car, it's a bit excessive as well. But it's recommended for this frequency for safety, performance, and long-term reliability. A Honda doesn't see the kinds of use that an M-B or AM will see - these cars are made for high speeds (performance driving, autobahn cruising, etc), so the brake systems are designed to see much higher wear rates.
Old Apr 29, 2016 | 01:22 PM
911MTB's Avatar
911MTB is infamous around these parts
If you are using very high temp brake fluid they tend to be more hydroscopic (absorb water particles) and need more frequent changes so every two years for these should be observed. If the car isn't track driven and a high quality (but not extreme) brake fluid is used you can stretch this out a bit longer. Just my opinion.
Old Apr 29, 2016 | 02:24 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
I would do it every 2 years, regardless of the car, obviously more frequently if the car sees any track usage.
Old Apr 30, 2016 | 08:04 AM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Porsche also recommend a brake fluid flush every 2 years for their cars.
CATTMAN
Old Apr 30, 2016 | 01:06 PM
J doubleU's Avatar
From what I've found is if it's a V12 model brake fluid should be changed every year or 10K. DB9/Vanquish/Rapide/12Vantage.
Old May 1, 2016 | 10:54 AM
Irish07@VelocityAP's Avatar
V8 Vantage is every 2 year, V12 Vantage/DB9/DBS/Vanquish is every year..Depending on the year of owners manual you have, it's explained in there.. Just in front of the service stamp done by the dealer.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old May 4, 2016 | 05:26 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
There is a cheap like $15-20 brake fluid tester like this one
http://www.ebay.com/itm/like/2820206...&ul_noapp=true
You can test water content and it will tell you, if there is more water content, then time to replace. On the other hand last night I replaced my Lambo brake fluid which was 2 years old. Water content was
halb
Oct 4, 2020 04:18 PM
will007
Sep 15, 2016 11:54 AM
ncamv8
Mar 31, 2016 09:05 PM
speedracer800
Mar 30, 2016 07:39 PM
