Function of Push Button Dimmer Knob (US Spec)?
Old May 17, 2016 | 04:01 PM
pikajew's Avatar
pikajew is infamous around these parts
Function of Push Button Dimmer **** (US Spec)?
2008 V8V Roadster..
Does anyone know what the push function of the dimmer **** is suppose to accomplish other than locking in the settings? Or is that it? FYI, I am unable to turn the interior dome light off when either door is open (the map light buttons on the dash only turn the map light on and off with the door closed).. Thanks!
Old May 17, 2016 | 09:19 PM
karlfranz's Avatar
Everything you describe is normal behavior. Of course, if you leave the door open long enough (around five minutes) the lights will shut off in order to preserve the car's battery. The push function of the dimmer use to help avoid moving is position when turning the other lights on/off.
Old May 18, 2016 | 10:56 AM
Irish07@VelocityAP's Avatar
Originally Posted by pikajew
2008 V8V Roadster..
The push function?
That's the dash dimmer switch, how bright or how dim you want the dash lighting when the headlamp switch is in the ON position. You push the switch, it comes out and you adjust..push it back in so that your pant leg doesn't catch it and snap a cheap piece of plastic clean off...and if it doesn't snap off, then it will turn and mess up the setting you had. So the "push function" is just an insurance plan of a new headlamp switch
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old May 18, 2016 | 09:37 PM
pikajew's Avatar
Thank you all for confirming!
Originally Posted by irish07
The push function?
away
Apr 27, 2016 03:54 AM
stanger911sc
911
Apr 23, 2016 02:13 PM
away
Apr 23, 2016 04:59 AM
laz74
Apr 21, 2016 04:03 PM
