Side Light replacement ?
Old Sep 8, 2016 | 03:38 PM
handyman2009's Avatar
Veteran: Canadian Forces
Those side marker are from Ford...
http://www.ebay.co.uk/itm/182239381029?clk_rvr_id=1090078882763&rmvSB=true
Old Sep 8, 2016 | 07:55 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Originally Posted by deckman
I wish you would have posted this earlier, I bought the other on ebay for about $60. The ones you referenced do look exactly the same and are about $7 each.
Ouch...
Old Sep 9, 2016 | 05:24 AM
deckman's Avatar
Yeah well I asked and saw what I thought was the only place to order. I wasn't going to dwell on it. Only about $45 lost.
Old Sep 9, 2016 | 12:45 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Originally Posted by telum01
5w 168 bulbs
Thanks again Telum!!
Old Sep 9, 2016 | 01:01 PM
telum01's Avatar
no problemo
Old Sep 16, 2016 | 07:36 PM
randyb's Avatar
I am going to paint them tomorrow, can someone tell me how to remove them?
Old Sep 16, 2016 | 08:52 PM
sdekoning's Avatar
Carefully rotate them 90 degrees (believe clockwise) and the notch will line-up with the recess/hole for you to be able to pull them out. Make sure the fitting+bulb remain outside or you may have to take the liner out..
Old Sep 17, 2016 | 08:22 AM
randyb's Avatar
Thank you
Old Sep 20, 2016 | 02:54 PM
deckman's Avatar
I got the replacements, now how do I get the darn thing out? I twisted the housing and it comes out, but what about the piece it's connected to? If I get it disconnected from that wired connector will surely fall into the well.
Old Sep 20, 2016 | 03:18 PM
telum01's Avatar
Super easy to access if you undo rear half of the fender liner.
Old Sep 20, 2016 | 04:13 PM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
When I removed the old yellowish ones to fit Ford Puma units they just disintegrated, you will need to trim the Ford item stlightly to get them on, the genuine were also trimmed.
aliarasheed
Sep 10, 2016 08:21 PM
Ruben-Unleashed
Wheels/Tires
Aug 31, 2016 06:27 PM
Ruben-Unleashed
Wheels/Tires
Aug 31, 2016 06:19 PM
Ruben-Unleashed
Wheels/Tires
Aug 31, 2016 06:00 PM
eddie89
Aug 31, 2016 05:54 PM
