V8V normal operating temp
Old Sep 15, 2016 | 05:52 AM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
My 2007 V8V runs with temp gauge at midpoint (50%) mostly (now done 4000km in it)
Long trip on weekend and noticed at high speed when outside temp drops to 15deg C the temp gauge drops to about 35%. As soon as you slow down to go through a town back up to 50%
Is that normal or have I got a stuck thermostat.
Advice appreciated
Graze
Old Sep 15, 2016 | 06:01 AM
telum01's Avatar
Not getting up to the 50% mark is a sign of a bad thermostat. Yours going back and forth makes me think it's just starting to fail.
The gasket goes bad and the thermostat has to be replaced. I've got a video on YouTube that goes over it failing and replacing it.
Old Sep 15, 2016 | 06:10 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Your thermostat is on its way out as telum stated. Mine was like that, until the car just barely reaches the 50% mark at all during the spring and cooler fall weather.
Just buy the kit from telum's website and DIY it. I barely worked on any of my prior cars before, and it took me 2 hours to do it including a lunch break in between.
Old Sep 15, 2016 | 01:39 PM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
Made the same experience, new thermostat and all back to normal.
Usually my temp reading is spot on 50%, just when I really push her hard, like a 2500 Meter mountain pass, it rises to 55%. Below 50% onle from cold start on to normal operating temp.
I hope I could help
Christian
PS: 50%=90-100 C, 55%=105-110 C
Old Sep 15, 2016 | 02:15 PM
Graze's Avatar
5 Year Member
thanks guys
that is what i suspected
Rich, have seen the video thanks, big help
will get it done next once i get the parts
Graze
onefastman1
Dec 15, 2016 01:49 PM
tbraden32
Oct 13, 2016 12:05 PM
mkrajo
Oct 5, 2016 06:20 PM
bct1192
New Member Introductions
Sep 22, 2016 11:26 AM
Sep 14, 2016 06:58 PM
