Negative earth points?
Old Nov 12, 2016 | 09:15 AM
00aston's Avatar
00aston is infamous around these parts
What are the some good negative earth points on a V8V roadster?
(In particular, around the trunk and centre console)
Old Nov 14, 2016 | 09:41 AM
embdenb's Avatar
Not sure there are any designated earth (ground) points in those areas, however if a good ground is required, I would suggest running a wire to the negative battery cable body ground point directly beside / below the battery.
Old Nov 14, 2016 | 10:22 AM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
Is the fuse box for the roadster in the trunk? Should provide plenty of points you could use for a ground.
Old Nov 14, 2016 | 02:59 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Battery is always the best, but there should be one near all the fuse boxes. Not sure about center console.
