new hub time? :(
Old Feb 12, 2020 | 08:10 PM
robertwroth's Avatar
robertwroth is infamous around these parts
Hard to find spec
Originally Posted by davidm17
You want to make sure the knurl length and diameter of the studs are correct for the holes. The knurl is designed to compress in the hole so I don't think you'll get a completely accurate measurement from one you pull out. You might have to add .1mm or something to it. I'd see if you can find the specs for the stock studs somehow.
Agreed - and I can't seem to find that info anywhere (I have the maintenance manuals, etc but this isn't listed anywhere that I can find it).
Old Feb 13, 2020 | 11:32 AM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Yeah. I did some searching and couldn't find it either. There's a thread on piston heads that has a link to an ebay listing, but it's long gone. Your best bet is probably what you were thinking - pull one out and take some measurements. Try and find as close a match as possible.
Irish07 on here seems to have a lot of knowledge so you may try PMing him.
Old Feb 13, 2020 | 12:07 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
There's no industry standard for the hole size for a press-in stud. The manufacturer of the stud has to provide it. Having said that, I've designed many, many systems with captive standoffs and studs and they all pretty much use the same hole size for any given thread diameter.
