lepreux
lepreux
aston clutch learn do you start car in n with foot on brake let it run for 10 secs
with a/c off .I normally let the engine run until the choke cuts out that normally
last longer than 10 secs dose it make any differents if its longer than 10 secs
On the Vantage S there is a flashing light while the clutch learn is taking place. It's slightly different in the earlier models.
https://www.6speedonline.com/forums/...procedure.html
Hi...On my 09 Put foot on brake..i start the car..Put in 1st...But most times leave in first not use just brake...Car goes into neutral and light changes in fob area showing clutch learned...If car has sat for awhile...Week...I repeat 3 times...Seems to help in lower gear moving...Never drive hard till temperature is at normal operation...
