Fuel lid solenoid
Old Apr 5, 2017 | 06:49 AM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
Fuel lid solenoid
So last night when I filled up the little nub that holds the fule flap down retracted but then was too shy to reappear. Right now I've just got a piece of paper wedged between the flap and the body to keep the door closed.
I'm hoping it's just gunked up. Anyone else work on one of these? Thinking I just have to remove the boot liner to get at it.
Old Apr 5, 2017 | 09:35 PM
Old phart's Avatar
So pulled a bit of the liner out. Saw the mechanism and just cycled it a few times and it seems to be back to normal. Was stuck on the down cycle. Squirted a bit of lube in the top end.
Took out these two bolts
Removed the boot seal so the liner could be pulled back.
Mechanism attached to the side of the fender with the cable going up to the latch. Pulled on the white handle a few times and cycled it with the release button too.
Old Apr 7, 2017 | 10:01 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Mine is stuck in the open position and I have tried everything I could think of to loosen it up, but no go. Just ordered a new cable from AstonParts and is under $50 shipped.
Old Apr 7, 2017 | 12:33 PM
Old phart's Avatar
I just added a roll of velcro to my trunk kit. If it happens again I can use that to hold it shut till I get home. This time I just wedged a piece of paper in there to hold it down.
Old Apr 7, 2017 | 10:37 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
I had little different problem. My button got stuck but I found my gas door was not lined up correctly. Once I corrected this problem and oiled the latch it has worked ok...Good luck...
Old Jun 16, 2017 | 06:55 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
My fuel lid is stuck. I can hear the solenoid but the latch doesn't move. I can open it with the release in the hatch. I have centered the lid and lubed the latch, but can't get it to move.
Old Jun 17, 2017 | 08:31 AM
Old phart's Avatar
If you can open it with the release then the cable must be good. Have you had someone press the button while you watched the solenoid to see if there is movement?
Old Jun 17, 2017 | 01:12 PM
Gene G's Avatar
I had my wife push the button and I watched to see if there was movement. I could hear it click but no movement.
Old Jun 17, 2017 | 02:11 PM
larryg's Avatar
larryg is infamous around these parts
Does anyone know how to adjust the alignment of the lid to the body.
Old Jun 18, 2017 | 07:33 AM
embdenb's Avatar
My alignment was slightly off and I removed the cap and hinge. Placed a couple of washers between the hinge and body to align the cap to the door.
http://bernardembden.com/am/gascapdoor/index.htm
Old Jun 18, 2017 | 07:48 AM
larryg's Avatar
That is a wonderful write up.
What type of quick set glue do you recommend?
Many thanks
Old Jun 18, 2017 | 08:17 AM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
Great write up, but are you sure:" I decided to MOVE the mounting point away from the body a centimeter or so" , wouldn't it rather a milimeter?
Old Jun 18, 2017 | 08:26 AM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Mine is rubbing on the bottom edge and the last 3 times I got gas wouldn't open without using the cable release and pushing the cap away from contact.
Is this misalignment adjusted by bending the arm? From the holes for the locating pins one is elongated like it would allow adjustment, but the other is not so I don't see how it could be moved.
Old Jun 18, 2017 | 10:55 AM
embdenb's Avatar
(Laugh)
You are of course correct. Now I have to correct the website (smile)
Old Jun 18, 2017 | 10:59 AM
embdenb's Avatar
Many thanks
Any quick setting glue will do (all you need is for the washers not to move as you insert the screws)
I used gorilla super glue
