How far should hatch "pop" up? V8 Vantage
Old Apr 7, 2017 | 11:54 AM
svre46's Avatar
svre46 is infamous around these parts
I recently purchased my first Aston. One annoyance is the hatch does not pop up very far when you hit the button to release it. Maybe 1/4 of an inch. Is this an indicator of weak hatch lift struts? They hold the hatch up fine once it is raised.
Thanks,
-Steve
Old Apr 7, 2017 | 12:05 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
All it's supposed to do is unlatch it, you do the lifting.
Old Apr 7, 2017 | 12:19 PM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
It's doing exactly what it's designed to do.
Old Apr 7, 2017 | 01:05 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
LOL its not an automatic lifting hatch, it just releases it, you have to move it up by yourself (yes it is sort of heavy compared to most vehicles)
Old Apr 7, 2017 | 01:44 PM
svre46's Avatar
Thanks. On my other cars they leave about an inch gap to get your hand under which is why I figured I would ask.
Thanks for clarifying.
It's not the issue of it being automatic. My fingers can scratch the paint lifting the hatch up because the gap between the bumper and hatch is so small. My z06 was the same way and the trick was to put pennies under the springs. I am an OCD freak for fingerprints or fine scratches so I just figured I would ask.
Old Apr 7, 2017 | 01:53 PM
svre46's Avatar
This is how it is supposed to be. Looks like I need to do some adjustments on the rubber bumpers (plunger?..not sure what it would be called).
Old Apr 7, 2017 | 01:54 PM
J doubleU's Avatar
That is about all you get, but you can check the rubber stops on the lid bottom. They contact the body opening on top of the tail lights. they have a "spring" assist center that aids in hatch opening. they break off inside of the hatch sometimes. looks like a phillips screw in the center. Gas assist struts have a date code on them xxx/XX first there digit is the day of the year followed by the 2nd digits being the year. IE 186/09 (186th day of 2009) replace all the vehicle struts hood/door/hatch at the same time.
Old Apr 7, 2017 | 01:56 PM
svre46's Avatar
I will check them out. Thanks for the tips!
Old Apr 7, 2017 | 08:45 PM
svre46's Avatar
I checked out the rubber stops. The center springs are shot! Thanks.
Old Apr 8, 2017 | 01:07 PM
5 Year Member
My springs are stiff and seem fine, but mine only releases and pops up about 1/4".
