I suck as a mechanic. Advice mating center section with muffler?
Old Apr 9, 2017 | 01:38 PM
deckman's Avatar
I cannot get the VAP x-pipe tubes to go into the rear muffler tubes. Advice please? The drivers side is where I'm having the main problem. It just won't seem to fit in. (that's what she said!)
Rich if you are out there I think I need you to come over and rescue my car.
Old Apr 9, 2017 | 03:00 PM
bunob's Avatar
bunob is infamous around these parts
Pics could help to see your problem ;-)
Old Apr 9, 2017 | 03:44 PM
embdenb's Avatar
Sometimes the old exhaust clamp can deform the inside diameter of the muffler pipe just enough to prevent the x pipe tube from going in. There are devices that will open up the pipe diameter. Try the local automotive part houses, they will sometimes rent these tools.
Old Apr 9, 2017 | 09:27 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
Yep.. ^^ what he said. "Advance Auto parts" or "O'Reilly auto parts" will loan you a "tail pipe expander" tool for nothing typically. It's a devise used to expand the inside diameter of exhaust pipes. You just insert and crank on the nut to expand the tubing a bit. It'll make a deformed piece of tubing nice and round again and give you a little bit more slack and clearance to more easily slide the sleeved pieces together.
Good luck! I'm sure you'll get it.
Old Apr 10, 2017 | 06:39 AM
deckman's Avatar
Thank you guys I really appreciate it. I was working on that for about two hours yesterday getting absolutely nowhere. And I have to tell you, one of my least favorite places to be is under a car on jack stands.
Old Apr 10, 2017 | 08:03 AM
deckman's Avatar
Why is one side shorter on the new xpipe vs the old original center section? Look at the end that goes into the where the secondary cats connect.
Old Apr 10, 2017 | 09:54 AM
deckman's Avatar
Stuart solved this one for me. The end piece on the original part comes out and is installed on the xpipe. So simple!
Old Apr 10, 2017 | 10:50 AM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
Got back last night and doing a lot of catching up... did you get it sorted out then? Everything installed and good to go?
Old Apr 10, 2017 | 01:35 PM
deckman's Avatar
This is the decat pipe passenger side attached to the manifold. Do you see the angle of that top stud? I can't get a nut on there because of the angle of the pipe. The RH marking on the pipe does mean the passenger side, right? Assuming it is installed in the right place, what am I supposed to do?
Old Apr 10, 2017 | 01:58 PM
deckman's Avatar
On another note, some installation instructions would have helped me along the way.
Old Apr 10, 2017 | 02:05 PM
Redpants's Avatar
Yes, RH is right-hand, which is passenger side.
Pull the pipe back from the manifold a little so that you can work the nut on, then you can push the pipe closer to the manifold once the nut is threaded enough onto the stud.
Old Apr 10, 2017 | 03:41 PM
bunob's Avatar
Just reverse the bolt to have the nut on the header side...
Old Apr 10, 2017 | 03:48 PM
deckman's Avatar
You can't do that, it's a stud attached to the manifold. I wish though. It was hard. I was working this, and my day job also as the day went on
Old Apr 10, 2017 | 03:54 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Hi John,
You just need to get the nut onto that stud when there's just a bit of thread poking through. Then you can start the other nuts/bolts and cinch it all up.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Apr 13, 2017 | 07:28 AM
deckman's Avatar
Well I got it. That top nut is a real bear. Luckily I have a set of crow foot wrenches and I was able to attach the 13mm to a short socket wrench extender and use that to gain a bit of leverage on the nut and hand tighten it as best I could.
