DBS Side Repeater Replacement
Old Apr 22, 2017 | 12:42 PM
m_motorsport's Avatar
m_motorsport is infamous around these partsm_motorsport is infamous around these parts
I have some issues with one of my side repeaters on my DBS, basically it has stopped working due to condensation. I have purchased a replacement and had a fiddle today to see how it fits.
Does anyone know how the repeater connects to the chrome/alloy wing strake, as from parts diagram it looks like it has two bolts coming in from behind, but mine has no bolts and looks bonded to the strake.
I tried removing the whole assembly as the strake and repeater can come out together, but i cannot seem to access to the bolt closest to the door, as there isn’t very good access.
Any ideas?
ID:	474879   Click image for larger version
ID:	474880   Click image for larger version
Old Apr 22, 2017 | 05:07 PM
handyman2009's Avatar
Veteran: Canadian Forces
It must be similar to my Vantage, you have to remove the mesh behind first which is held in place with 3 nuts, then 1 big nuts at the front of the Stalk and 1 bolt between the door and the fender (the bolt is a @#$ to undo but it is doable, I use an open/close end wrench and go very slowly. The first time I tape up the door and the fender to protect them. I assume that you will have to undo a connection to your current light before pulling the Stalk out. It is also held in place with 2 way tape so once you have all the nuts/bolts out you might have to pull a little but be careful. Good luck, I have mine out now to get them powder coated black along with the mesh behind them
