Brake Fluid Condition Monitoring
Old Apr 24, 2017 | 05:03 AM
drivergmx's Avatar
drivergmx is a jewel in the roughdrivergmx is a jewel in the roughdrivergmx is a jewel in the rough
Has anyone used any of the brake fluid test strips available to determine PH levels or the LED test pens to detect percentage of water content for determining current brake fluid condition?
Old Apr 24, 2017 | 06:47 AM
svre46's Avatar
svre46 is infamous around these parts
I use the LED test pen. This is the one I have.
https://www.ecstuning.com/b-schwaben.../015745sch01a/
Old Apr 24, 2017 | 10:29 AM
drivergmx's Avatar
Reminds me of the zerowater HMD TDS test pen. Only instead of checking for contaminants in the water, the water is the contaminant... Brilliant!
Old Apr 24, 2017 | 10:43 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
If you follow the factory maintenance schedule these tests will show no issues with the fluid. Making the tests unnecessary.
Old Apr 27, 2017 | 12:10 AM
djantlive's Avatar
It won't detect bubbles right?
Old Apr 27, 2017 | 11:58 AM
embdenb's Avatar
Every time you open the brake fluid system to check the moisture level you introduce moisture into the system.
Old Apr 27, 2017 | 04:10 PM
deckman's Avatar
Does the pen work? Is it accurate?
