Lube your shifter linkage!
Old May 3, 2017 | 04:08 PM
silver997's Avatar
silver997 is infamous around these parts
Hello. When i first got my 6 speed manual Vantage i always thought the shifter felt very unrefined. Especially from neutral into any gear. I thought changing the transmission fluid would help. It did to some extent. I had the arm rest console and shifter out of the car and noticed the shifter linkage and shifter cables looked like it they hadn't been lubed in a while. I lubed the linkage and cables. What a difference. If you haven't done this you should. Makes all the difference. I highly recommend it.
Old May 3, 2017 | 04:49 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
So for a 6-speed manual transmission, I should remove the center console and
"lube the shaft"
Old May 3, 2017 | 05:57 PM
silver997's Avatar
"lube the shaft"
I was gonna call this thread "lube your ****". I didn't want to start with the moderators. LOL
Old May 3, 2017 | 06:00 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Mine was shifting stiff until they did the clutch, where I'm pretty sure they lubed the cables because it shifted very smooth when I got it back.
Old May 4, 2017 | 07:09 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Is there anyway for a DIYer to get a grease nipple to one end or the other without removing the linkage from the car?
Old May 4, 2017 | 07:24 AM
Jagman70's Avatar
Jagman70 is infamous around these parts
Shifter Lube
What year is your Vantage??
Old May 4, 2017 | 08:59 AM
silver997's Avatar
Originally Posted by jagman70
what year is your vantage??
2009
Old May 4, 2017 | 09:13 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
yeah so what all is involved with greasing the linkage
like how much stuff do I have to take apart?
Old May 4, 2017 | 10:29 AM
silver997's Avatar
http://www.redpants.lol/armrest-and-...nsole-removal/
Once you have the leather shifter **** out you can see where all the pivot points are for the entire shifter mechanism and the cables. Apply solid white lithium grease to everything.
I can't believe this dealership serviced car never had the transmission fluid changed. I searched all the service records. I think the service interval is 5 years. The fluid was pretty black.
Old May 4, 2017 | 11:10 AM
sonies's Avatar
5 Year Member
sounds like a project I will have to undertake once I get my DBS metal shift **** !
Old May 4, 2017 | 11:21 AM
silver997's Avatar
As far as removing interior parts goes i usually use masking tape on the areas i think might be damaged by rubbing solid surfaces on the leather. Especially when lifting out the metal shifter base. Be careful.
Old May 6, 2017 | 04:54 PM
VANTAGE_06's Avatar
5 Year Member
VANTAGE_06 is infamous around these parts
Yeh mine is the same, I am going to check this out this weekend. Did you merely lube the rod that passes in and out of the outer sheath?
