07 DB9 Linn 950
Old May 9, 2017 | 07:55 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
07 DB9 Linn 950
My sub sounds like a very loud bowl of rice krispies, so I have a few issues.
1) Where is the stupid sub?
2) Replaced the door speakers w/Focal's and they do not sound good, should I have hooked up the tweeter wires also?
3) Are there any subs that will fit in the stock enclosure or is it junk and I should ditch it and get something else?
4) When in Dolby mode, the system sounds like crap, but when I switch it off the system sounds pretty good, except for the the sub and door speakers. Anyone have this issue?
Old May 9, 2017 | 09:00 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
1. SUB is between the back seats on the center panel at the very top portion. I think you need to remove the section behind the center console, then you can remove the grate on top of the sub. 8" sub I think. Likely anything that fits should be fine, but not sure. There are a few Youtube videos showing installs so you can look at that.
2. Yes you should have hooked up the tweeters. Without you have no Highs and only the mid level tones and sub tones. Likely crap sounding.
I think what I posted should take care of what you want. Not changing anything in mine, except Denison
Old May 9, 2017 | 09:56 AM
randyb's Avatar
Oops, I was thinking that and of course changed my mind and thanks for the help!!
Old May 9, 2017 | 10:48 AM
randyb's Avatar
What is the stock sub size?
Old May 9, 2017 | 01:23 PM
J doubleU's Avatar
950 watt Linn is a 10" really nice build aluminum cone. Base is 8" paper cone. I doubt anything is wrong with the driver.
Old May 11, 2017 | 08:37 AM
SheriffDep's Avatar
OK, I learned something, thought they were all 8"s. I guess just like in life, some have larger ones than others
Old May 12, 2017 | 02:25 PM
randyb's Avatar
You would be correct, turned off the sub and heard the crackling coming out of both my rear speakers, so I am ordering another pair of Focal's for my rears.
Weird thing is the rears did not do that before I turned the sub on.
Old May 12, 2017 | 03:26 PM
J doubleU's Avatar
What model of Focal's are you using to replace the OEM speakers with?
Old May 18, 2017 | 11:27 AM
randyb's Avatar
Forgot to answer this -
Focal Access 100CA1 SG 2-way 4"
