AM V8V OBD Codes
Old May 10, 2017 | 01:00 AM
bunob's Avatar
bunob is infamous around these parts
AM V8V OBD Codes
Hi all,
I have the codes list for DB7 and DB9 but I haven't for the V8 Vantage.
The DB7 DB9 codes skip from P1935 to P2105.
I have the code below :
P2073 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
What is the problem ? MAF sensor ?
Can someone give me the list of the code for a V8 Vantage MY2006 ?
Thx
Old May 11, 2017 | 10:54 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Here is some info
File Type: pdf
File Type: pdf
Old May 11, 2017 | 02:15 PM
bunob's Avatar
Thanks,
Then to solve the problem :
Step 1 : I clean my throttle body.
Step 2 : I clean my MAF sensor.
Step 3 : I check for air leaks in the ducting, between MAF sensors and the throttle body.
I'm right ?
Other steps ?
Old May 11, 2017 | 06:56 PM
rmrmd1956's Avatar
sounds about right.
oiled aftermarket air filters = fouled MAF
front end damage or prior intake system repair = consider air leak
over 4 years since throttle cleaned = consider sticky throttle, see: https://www.6speedonline.com/forums/...8-engines.html
