Radio cuts out after taking dash out
Old Jul 16, 2017 | 03:31 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
So I took the dash out to fix the tinting that went bad, now after putting the dash back in, the radio cuts out from time to time and after a minute or two will come back on.
Anyone know what might cause this and more importantly, how do I correct this issue?
Old Jul 16, 2017 | 07:32 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Did you pull the entire dash? Or just the instrument cluster?
Old Jul 17, 2017 | 08:21 AM
randyb's Avatar
Just the cluster
Old Jul 17, 2017 | 12:34 PM
Timodc's Avatar
5 Year Member
There's really nothing behind the cluster that would affect audio. Could be something unrelated.
Old Jul 17, 2017 | 01:52 PM
svre46's Avatar
svre46 is infamous around these parts
I have not seen the back of an Aston Cluster. Is this on the MOST-BUS loop? If so; maybe a loose connection there.
Old Jul 17, 2017 | 01:54 PM
randyb's Avatar
It started right after I pulled the cluster, that is a very strange coincidence. Going to try disconnecting the battery and putting the + and - cables together and see if that does not help.
randyb's Avatar
Could be, I will check that out.
Old Jul 22, 2017 | 01:37 PM
randyb's Avatar
Well, disconnected the battery and now the radio will not even turn on.
Bright side, the tinting on the digital displays looks great.
Old Jul 23, 2017 | 09:10 PM
bonnie sacer's Avatar
bonnie sacer is infamous around these parts
something wrong with the radio connection?
Old Jul 24, 2017 | 09:40 AM
randyb's Avatar
Anyone know where the radio HU is located?
Old Jul 25, 2017 | 10:59 AM
randyb's Avatar
Nope, just the connector. This is driving me nuts, only thing I can think of, is that there was a electrical spike and it hit the radio and bluetooth.
Bluetooth is not working as it should, a call comes in and I hear the phone ring through the speakers once and then nothing.
Old Jul 25, 2017 | 05:28 PM
Rwp137's Avatar
Rwp137 is infamous around these parts
Try this...
Old Jul 25, 2017 | 06:12 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Did you sync your phone again after the battery disconnect?
If I don't resync once a weak it'll lose contact. The BTooth in these cars is not a strong point.
Old Jul 26, 2017 | 07:57 AM
randyb's Avatar
I did not, I will try syncing my phone again.
Thanks!!
Old Jul 27, 2017 | 04:21 PM
randyb's Avatar
Originally Posted by Rwp137
Thanks, but the DB9 does not have the switcher.
