EMS-P Fail??? (DB9)
Old Sep 28, 2017 | 09:33 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
EMS-P Fail??? (DB9)
I just did the DB9 coil pack replacement project on my DB9 (thanks to Aston1936's brilliant directions!) and the car is running great...smoother, in fact, than I ever recall.
I bought the Aston Martin-specific Foxwell NT510 diagnostic tool and plugged it into the OBDII port, and it's reading "12 Cylinder EMS-P Engine Control Module Bank 1 FAIL."
If I use the regular OBDII functions of the tool I don't see any failure codes and my Actron CP9575 OBDII scanner isn't showing any codes, either. As I said, the car is running great.
Does anyone know if a failed primary engine control module would throw a code that a regular OBDII tool would find, or is the Aston Martin-specific feature set of the Foxwell NT510 revealing something that is otherwise hidden?
Thanks!
