Service alarm system message and associated clicking
Old Oct 1, 2017 | 11:08 AM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
2005 DB-9......Message appeared after a drive and now with the car sitting in the garage there is a clicking that randomly occurs. It sounds the same as the tone that occurs when you lock/unlock the vehicle using the fob. Any ideas on what's occurring and what the fix is? Thanks in advance.
Old Oct 1, 2017 | 01:23 PM
Dustan's Avatar
Dustan is infamous around these parts
Possible battery slowly failing
Old Oct 1, 2017 | 02:55 PM
supraholic's Avatar
supraholic has a spectacular aura aboutsupraholic has a spectacular aura aboutsupraholic has a spectacular aura about
Yep, sounds like you need a new alarm module. The battery inside this unit is likely failing. I had the exact same message on my V12V and installing a new alarm sounding unit fixed the issue (https://www.6speedonline.com/forums/aston-martin/411569-alarm-system-service-required-2012-v12v.html). AstonMartinBits.com will hook you up with the correct unit based on your VIN.
Old Oct 3, 2017 | 09:29 AM
DonBond's Avatar
Originally Posted by supraholic
Yep, sounds like you need a new alarm module. The battery inside this unit is likely failing. I had the exact same message on my V12V and installing a new alarm sounding unit fixed the issue (https://www.6speedonline.com/forums/...2012-v12v.html). AstonMartinBits.com will hook you up with the correct unit based on your VIN.
I think you're on to something here. The battery is very strong. I will check with AMBits. Thanks
Old Oct 3, 2017 | 09:36 AM
DonBond's Avatar
I wonder about disabling the alarm for the short term so it doesn't make that clucking chicken sound,
Old Oct 6, 2017 | 12:58 PM
DonBond's Avatar
Update.......After putting my battery conditioner on the car for a few days the clucking chicken has stopped.
