AM Friends beware
Old Nov 21, 2017 | 11:26 AM
RJRDenver's Avatar
RJRDenver is infamous around these parts
I have this problem all the time, assuming you're talking about the door not popping open. I've resorted to almost always skipping the fuel release button in the car and just using the manual release in the trunk. I also have to fiddle with the door while pulling the release. The dealer has attempted to fix it once, but I figure its the price of a hand assembled, limited quantity production type vehicle. It's bound to happen.
Originally Posted by oo7
Discovered my gas cap does not open this morning. It was never an issue before, A recall issue they addressed while the car was there. I am now afraid of what else I may discover...
Old Nov 21, 2017 | 11:55 AM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
there's a release in the trunk? is that in the manual somewhere?
Old Nov 21, 2017 | 01:48 PM
RJRDenver's Avatar
I would think its in the manual, but basic info is also omitted, so here is some details.
Inside the trunk area on the drivers side, there should be a small panel that opens. behind it is the white manual pull release pictured below indicated by the red arrow. The picture below shows the whole left side of the trunk area removed, the access panel is actually much smaller, but you'll get the idea. You're looking for that small round pull tab.
Old Nov 21, 2017 | 02:00 PM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
Thanks, I was aware there was another way to release it. Just not too pleased that before the fix there was no problem and now there is. Perhaps it would have eventually failed with out the recall fix, but it was fine for over 100k miles...
Old Nov 21, 2017 | 03:12 PM
RJRDenver's Avatar
Smile
Luck you lasting a 100,000 miles. LOL. I only had 26,000 miles when it started.
Old Nov 21, 2017 | 04:46 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
6000 when mine started. There are some trick fixes where you remove the cap complete with arm and shim the side it sticks on the center it. Or, just bend the arm a little and it'll be find. Don't try to break it, it doesn't take much.
