2012 V8 Vantage S
Old Nov 18, 2017 | 01:14 PM
handyman2009's Avatar
Veteran: Canadian Forces
if you are doing it yourself check Redpants.lol for parts pricing, Rich have good price.
Old Nov 19, 2017 | 10:13 AM
V12Vin's Avatar
V12Vin
Originally Posted by Z71TahoeEX
What does a brake job typically cost?
I am guessing 2.5 hours to swap pads and brake flush. Including jack up car, remove/install wheels. Hourly rate are like $220ish. Pads maybe $250 to $400 an axle.
Old Nov 19, 2017 | 11:32 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I just had the rears done at my local AM dealer and was around $1200. To clarify, I already had new pads, they replaced the rear rotors and brake flush. The local dealer is $150 an hour and also quite thorough when it comes to inspection. Sometimes parts are discounted for whatever reason. No complaints on that.
Old Nov 20, 2017 | 11:27 AM
oldfool's Avatar
oldfool is infamous around these parts
I would
Old Nov 25, 2017 | 08:57 AM
Z71TahoeEX's Avatar
Z71TahoeEX is infamous around these parts
Got the PPI back....
Rear tires thin at 4mm, front ok at 6mm
Brakes ok, front 9mm, rear at 6mm
Clutch reading at 1470, replacement at 1750 on average
Battery tested ok
chip on passenger inside door handle
3 bumper covers lamps water intrusion
center bumper grill slat broken
Thoughts?
Old Nov 26, 2017 | 02:50 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
What's the actual mileage?
In your initial post, you said "very low miles", which is what?
Five year old tires will need replacing soon, regardless of the mileage, but can indicate the driving style of the previous owner.
Recommendations will vary according to the distance traveled .
Old Nov 27, 2017 | 09:12 PM
Z71TahoeEX's Avatar
10,000 miles
Old Nov 28, 2017 | 08:06 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
a new grill will cost you about $600
you can't buy individual slats unless you get lucky on ebay or something
what lights are messed up on the front bumper?
Old Nov 28, 2017 | 09:41 AM
Z71TahoeEX's Avatar
The turn signals have a little water in them on the fenders. Hardly noticeable.
