Best looking wheels on vantage ??
Does anyone know the exact specs of these wheels?
http://www.astonmartin.com/en/access...diamond-turned
The widths x offsets for front and rear?
Front wheels 8.5x19" ET 49 tires 235-40-19 Bridgstone
Rear wheels 9.5x19" ET 58 tires 275-35-19 Bridgstone
https://www.6speedonline.com/forums/...els-tires.html
I have exact set of those for ale. here is my wheel specs. listed in marketplace.
20x8.5 ET 40
20x10 ET 42
If I'm understanding the calculator correctly here https://www.1010tires.com/Tools/Whee...et-Calculator#
On the fronts, I will have 9mm of inner clearance and 9MM extend outer position
On the rears, I will have 10mm of inner clearance and an extra 22m of outers
I may be sticking outside the fenders just a little on the rears no? But I should be able to clear brakes and not rub? I am still trying to understand offsets and clearance
I have a V8V as well
Offset Front 42.1 Rear 54.0. They really compliment Vantage design
Beautiful car. Hope you enjoy it.
007JB, your setup looks great, is your car a V12 Vantage? Stock height or lowered?
Thanks, it's V8 with V12 custom painted grill. Yes, it's lowered about 3/4 inch all corners.
