2013 Vantage Analog Clock Sync
Old Jan 15, 2018 | 11:17 AM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
When day light savings hit the analog clock in my car didn't change to match the satellite time shown in the Nav. I've read all the threads I could find on here and PH. One thread said to unplug a gray connector under the carpet on the transmission tunnel (presumably it is supposed to contain the wires for the clock). I found the connector and unplugged it. It reset the Audio system, but didn't do anything to the clock. Some other threads say you have to disconnect the battery to get it to reset. I'd prefer not to do that as the ECU will lose the stored correction factors. I've thought about taking the center stack out and seeing if I can unplug the clock itself to see what that will do. Anybody had any luck getting the clock to resync?
In 2 months it'll be the right time again, but it'd be nice if the clock stayed in sync with the satellite time. Why they didn't just keep the little holes to set the time I have no idea.
Thanks.
David
Old Jan 15, 2018 | 01:34 PM
J doubleU's Avatar
Check the NAV setting for the clock, make sure the box is checked for "auto". 2013 MY saves the corrections, you can disconnect the battery.
Old Jan 16, 2018 | 12:20 PM
davidm17's Avatar
5 Year Member
Auto is checked for time in the Nav. I tried unchecking it and manually setting the time to see if the clock would changed to the manually set time, but it didn't.
Old Jan 16, 2018 | 09:00 PM
J doubleU's Avatar
Battery is your only option, you will not loose any settings.
forcefed1
Dec 30, 2014 07:07 AM
wildjeff
Cayenne 958
Aug 28, 2013 07:10 PM
griffinto
Apr 23, 2012 09:52 AM
