Racing seats
Old Dec 24, 2018 | 08:01 AM
  #31
DetomasoGTS74's Avatar
Originally Posted by era2076
I have a set of Nogaros being shipped. Not sure where they are, but I think they are close. If you can wait, I will post up the weights when I get them.
chr
That's great CHR! What did you end going with for the shell, GRP or carbon? I'm having a hard time justifying the additional cost for carbon. Also did you have them match your leather and do Alcantara in the middle?
I saw on a BMW forum where Cobra was able to reuse OEM seat heating mechanism in new seat (customer supplied), any other hints before I call them?
appreciate you posting the OEM weight with rails and the nogaro with rails. Then we can also compare to BrunoB.
Old Dec 24, 2018 | 12:01 PM
  #32
era2076's Avatar
era2076 is infamous around these parts
I went with GRP. I too could not justify the cost of carbon. Mine are not special. I did not even match the stitching. They are all leather in black.
I will post weights for the both OEM and Cobra with seats and hardware separate.
chr
Old Dec 25, 2018 | 11:31 AM
  #33
bolteon's Avatar
5 Year Member
bolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud ofbolteon has much to be proud of
When I took Centenary 23 to Chuckwalla with AM San Diego a few weeks ago- after the first half day of lapping, the lack of bolster and thigh support was killing me. Especially since the car is a manual.
I started dreaming about putting in some proper buckets in the car not only to save the existing seat from wear, but to also get me some decent support (my old daily driver was a 1965 Mustang Fastback with Recaro buckets).
Looking at Cobra's offerings, any particular reason why everyone leans towards the Nogaro's? What about railings- who makes them?
Any reason why not to consider the Misano? Deep thigh support for the win...
What about a 4 or 5 point harness? Mounting points?
I'm sure someone here has gone down this route...
Old Dec 25, 2018 | 08:37 PM
  #34
era2076's Avatar
Nogaro
This new, aggressively styled seat features a similar profile to Cobra's technically advanced race seats but minimises the compromises normally associated when fitting race seats to a regularly used road car. The side and shoulder bolsters offer great levels of body support but allow easy entry and exit and the base profile allows the seat to be mounted very low in the car if that is your favoured driving position. Designed to be used with a standard lap and diagonal seatbelt without modifications but also features harness slots for a 4 point harness if you venture out onto track at the weekend (Circuit version). The Nogaro is available in two shell materials, GRP and Carbon and with or without harness slots in a wide range of fabrics, colours and custom trim options.
I purchased the Circuit.
Allows for incorporation of a harness for track work, but will still work with OEM 3 point belt system for the street.
The least intrusive side bolsters (street), but significant improvement over stock bolsters for track
Cobra has the bracketing worked out for the Vantage
Lighter weight - we are installing manual tracks
Fixed back compromises maintenance e.g. pull seat to replace battery, rear shelf access reduced
Fixed back increases seat rigidity
The Circuit comes setup for submarine belt.
Lot's of seats out there and everything is a compromise. Nogaro was as close as I was willing to go to a full race seat. If we were not tracking the car I would not consider it. It seemed like a good compromise for our purposes. That we can retain and use the 3 point belt system was the deciding factor.
You'll need a harness bar. VAP can help you.
chr
Old Dec 25, 2018 | 09:10 PM
  #35
bolteon's Avatar
5 Year Member
chr
Tip of the hat to you sir...
http://www.velocityap.com/Aston-Mart...tage4point.htm
Just what I was looking for.
I'll put in a call to Cobra about the mounting brackets. I would prefer to just go solid mount with the seat itself.
Old Dec 25, 2018 | 09:18 PM
  #36
bolteon's Avatar
5 Year Member
@Stuart@VelocityAP
Could I bother you for the installation manual on that 4 point half cage? Just want to be mindful of what I'm going to be cutting permanently, the website mentions it's carpet mainly... want to be sure since this is Centenary 23 we're talking about.
Old Dec 25, 2018 | 11:28 PM
  #37
FR500GT's Avatar
FR500GT is infamous around these partsFR500GT is infamous around these parts
They hosted a track day this year? I went with Jag/AM last year through Newport Beach but they are currently going through new ownership so they skipped this year. I ended up doing Buttonwillow through Speed District but not in the Vantage.
I'm looking to do fixed seats in the next few months and after sitting in a few different brands/models I'm pretty set on the Racetech RT4009w (Stealth):
[img]https://racetech-usa.com/shop/image/cache/data/seats/4009W-stealth2(800px)-800x800.jpg
Old Dec 25, 2018 | 11:44 PM
  #38
bolteon's Avatar
5 Year Member
Any particular reason you went with the Racetech route?
Old Dec 26, 2018 | 04:24 PM
  #39
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
@Stuart@VelocityAP
There's not one at present. We're just about to make one for another forum member, if you want to get one ordered we could do both at the same time.
Really, your main thing is going to be removing seats and protecting surfaces from being scratched. Once you have marked the locations for your holes, you'll need to drill those with an M10 drill (probably drill pilot holes first) and install rivet nuts with a setting tool.
If you want to do as Cliff had suggested and try to mark out and drill holes in the rear panel, you could also probably manage to slide that over the rear stays instead of cutting a slot. There's not a whole bunch of trimming to do.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old Dec 27, 2018 | 12:10 PM
  #40
bolteon's Avatar
5 Year Member
Noted, I'm assuming it's 16 holes that get made then, correct? Those are permanent but are under covers if reversed?
Any photos would be very helpful...
Old Dec 27, 2018 | 12:34 PM
  #41
It's actually a few more than that. We added in some side plates to the hoops on the main feet. Everything can go in without trimming the carpets if you want to keep them in. Won't quite sit flat in the back corner.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old Dec 27, 2018 | 03:21 PM
  #42
bolteon's Avatar
5 Year Member
Very helpful...
So it looks like this back board above the battery tray is the only piece that needs to be cut permanently. Is there a particular name for that board? Just curious on getting a replacement quickly.
The carpet down by the base of the seats I don't mind being out of place slightly...
Old Dec 27, 2018 | 03:32 PM
  #43
I don’t know that it has a name per se. certainly we can find the part number and order you one. If you want to make it reversible we actually used some Alcantara and spray adhesive on this car. You could do something similar and then preserve your OEM piece.
Old Dec 27, 2018 | 04:03 PM
  #44
bolteon's Avatar
5 Year Member
If you have a chance, shoot me a part number- I'm not ready to pull the trigger yet, between the cage- the seats (in CF, with refinishing to match the existing leather) and some harnesses... it's a $15k upgrade.
Old Dec 27, 2018 | 04:19 PM
  #45
bolteon's Avatar
5 Year Member
Actually, according to this:
The part number is:
6G33-60028-ABW
