Battery R & R V8 Vantage Manual
I connected my Schumacher memory saver cable during the battery swap, to the left (driver's side) OBD port. Intent was to avoid losing Engine Misfire Correction Factors. But there's an OBD port on the passenger side, as well. Did I keep the wrong OBD port powered up ?
Hi....no the left is the correct one...if not sure see the latest Ryan thread and shows the OBD 11 readings...including misfire during inspection of his car.
In NJ they inspected using the driver side port...
Good luck...
Good luck...
Thanks very much to you, and to all who responded ! I am very new to all this, and to AM ownership. Again, thanks.
Hi....no the left is the correct one...if not sure see the latest Ryan threat and shows the OBD 11 readings...including misfire during inspection of his car.
Good luck...
Sorry, I dont know what is "Ryan threat ?"
Good luck...
John in Norcal
Dec 12, 2007 09:44 AM
