lookind of Broken db9 right side tail light
Old Jun 21, 2018 | 07:17 AM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Hi Fellas,
I got notorious water in tail light in my 2009 DB9 Volante. Everything works except Brake light which is very dim and flickers. I intend to back it and open up the light to see where the problem is.
I also am planning to connect LED directly to 12 V battery to see if fault is in LEDs or is in circuit board.
Is there any one out there with damaged tail light, broken cover but not water damaged to help me do some transplants of the parts? or has it been done by any one before?
I promise to post a detail post about how its doen if its successful it will save a lot of trouble for other AM owners.
I also think that as soon as one buys an AM they should loosen the mounting bolt for tail light to minimize pull on tail light which leads to separation of glue.
Also once could put extra RTV adhesive to make it water proof before it leaks
Old Jun 21, 2018 | 07:18 AM
I am sorry for typos, I was in hurry plus I type with 2 fingers
Old Jun 21, 2018 | 10:21 AM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Another 2 finger warrior.
You are correct, when they replaced my rear lights I said it won't matter, they'll just do it again. But was corrected, it has alot to do with how tight they're fitted, and over a year now not even a hint of condensation.
Old Jun 21, 2018 | 11:18 AM
Db9 tail light
Mine is 2009 and suddenly now I have condensation issue pop up, so we should be doing preventative maintenance on these tail light as eventually they fail and glue separates.
If if you see online guide on how to open them ?
People use heat gun or bake then to separate lense from the body so if you live in hot climate this will happen anyway as those metal around the tail lights can get very hot when parked in sun.
Old Jun 21, 2018 | 11:22 AM
Matt
in your case was some Of the LED WORKING while others were not? My thinking was it must be LED itself as indicator, reverse they all work plus some of the led in brake light still comes on
could you please post some detail instructions on how to design circuit board to salvage it ?
Thx
Old Jun 22, 2018 | 07:28 PM
Led board
Originally Posted by hsm precision
Hi,
All the LEDs worked fine - it was something on the circuit board that failed.
The reverse lights are regular incandescent bulbs, so they should not go out.
To open the light, I heat the whole think in an oven on a pan. I think the temp was about 230F, but you will want to start at 200 or so, then increase the temp in steps until the seal breaks down. Too hot, and the plastic will deform. I used plastic pry bars to pull it apart once the seal is soft.
Attached is an image of my first board - there were a few errors, but I'm still using it 6 months later. I used Linear Technology LED drivers, and used LTSpice to figure out the correct values.
matt
May be you should start selling these boards ?
It looks way too complex to me, i can open the tail light, get the board out and ship it to you, can you help me fix it? or can you write up a nice easy to understand DIY for this?
Thanks.
K9COP
Apr 20, 2019 01:33 PM
Lve2xlr8
Apr 19, 2017 03:30 PM
first_911
May 14, 2015 03:21 PM
Zbird
11
Nov 9, 2013 08:08 AM
skeeter
Aug 23, 2011 08:27 AM
