Hard to start when gauge is around 1/4 of a tank
Old Aug 4, 2018 | 10:57 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
First try car will try to start and then cough and die and only when the tank is a 1/4 full or less. Will almost always start the second time. First I thought poor quality gas, so I stopped going to Shell and started going to Chevron or BP, but no difference.
Does it sound like water in the tank?
Old Aug 4, 2018 | 11:50 AM
embdenb's Avatar
you need to get into that tank. It could be water or a pin hole in the pickup tube
Old Aug 4, 2018 | 12:02 PM
J doubleU's Avatar
You're losing prime on one or both pumps. Try several on off key cycles to build pressure before starting. It may not be the fuel level it maybe temp related meaning less fuel = higher temp. Check valves in fuel pumps will bleed off, sometimes at a quick rate (seconds) do you have a scan tool to check PIDs for fuel pressure?
Old Aug 4, 2018 | 05:34 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Suggest not having fuel go lower than 1/4 tank. The fuel cools the fuel pumps and to constantly run low, the pumps will be overheated and damaged. It could also be if you ran stale fuel in the past.
Old Aug 5, 2018 | 01:30 AM
divetheworld's Avatar
divetheworld is infamous around these parts
Sounds like it could be evaporative emissions control valving to me. The whole tank and pipe work are setup to avoid letting fumes escape into the atmosphere. This makes it a sealed system.
So, to avoid a vacuum as you use gas, the valving allows air in and fumes to vent through the engine.
You could have a faulty valve, blocked carbon filter, even a faulty gas cap.
Too many bits to diagnose and tell for sure on here.
http://dannysengineportal.com/evapor...ontrol-system/
https://www.redpants.lol/blog/2015/1...alling-problem
cosworth
Jan 14, 2016 09:44 PM
TwinTurboM3
Jan 26, 2014 08:48 PM
DaveFL1976
Dec 4, 2013 10:08 PM
trojanman
Jul 23, 2008 09:27 AM
