quickjack 5000 lift of v8 vantage
Old Mar 25, 2019 | 03:58 PM
MRCW's Avatar
Fyi. Home depot email I received has quick jack 5,000 lb. lb.. $999
Old Mar 26, 2019 | 06:16 AM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
I've been thinking of getting a quick jack to use at our home and also use it at my shop on the 4 post when I what to do suspension work (turn 4 post into a 2 post).
Old Mar 29, 2019 | 11:14 AM
JPS-ATL's Avatar
JPS-ATL is infamous around these parts
Just noticed that Costco is running a sale on the Quickjack 5000. $999 with free shipping. 110V version only I believe.
Sale ends today, then presumably reverts to $1,099.
Old Jul 14, 2019 | 10:45 PM
voodoocat's Avatar
voodoocat is infamous around these parts
Hello, FYI I use a hockey puck, M8x35 bolt and 3/8" ID fuel line cut to 1/2" to create a 'plug' that inserts into the mounting hole. It remains intact in the car when lifting with the Quickjack. (of course, don't forget to remove after you are finished working on your car). Drill a smaller hole in puck and screw in the bolt. Tighten slightly to 'crush' the hose enough so it will stay in mounting hole. The groove cut in puck is for another car with pinch weld.
Note on Quickjack: Make sure to lock BOTH sides, if only one side is locked and didn't check other side, hydraulic pressure can flow from one side to another, eg if one side is slightly heavier than other. You can end up with unlocked side collapsing.
Old Jul 15, 2019 | 04:02 AM
MRCW's Avatar
I love this idea... I've been using the rubber blocks that come with the quick Jack but these seem ideal...I didn't think the custom pads were worth $200 to me to purchase
Old Jul 15, 2019 | 12:15 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
I was at Costco the other day and noticed these are $999 still for the 5000
considering getting one... but if they will ship it to my house for free that will definitely save my back a bit hah
Old Aug 27, 2020 | 08:09 AM
MichaelD's Avatar
MichaelD is infamous around these parts
Originally Posted by handyman2009
Yes there is one for each side of the car, it also has an hydraulic pump and a up/down remote controller... There are different size 3500lb, 5000lb... I got the 3500lbXL and it was just about $2000 Canadian, great investment to do any work on the car. Each Ram or side weigh about 75lb and it takes about 5min or so to set them up and start lifting the car.
I've been debating which model to get, is the 3500lb one OK for these cars? They are over 3600lb, I wouldn't want to accidentally leave my phone in the car and break the jack with the extra weight
With lightweight seats and wheels and a bit of carbon fibre I've got the weight of mine down to 3520lbs. If I bought those 2-piece Brembo discs I keep lusting after then I'd get under 3500lbs and wouldn't have to buy the more expensive jack. Isn't man-maths a wonderful thing ...
Old Aug 27, 2020 | 08:45 AM
handyman2009's Avatar
Veteran: Canadian Forces
The 3500lb would probably be ok but I opted to get the 5000lb as the price was very similar
Old Aug 27, 2020 | 08:47 AM
MRCW's Avatar
based on where you are, the 5,000# unit goes on sale at Costco for $1100 or less...
works great and I use it on my pickup
Old Aug 27, 2020 | 11:09 AM
MichaelD's Avatar
In the UK the Costco price is £1,356, equivalent to $1780 USD. The 3500 is £1122 so it is around $300USD less. If the 3500 can handle 5% more than its rating, then I think I'll put that $300 towards new lightweight Brembo rotors
Old Feb 4, 2022 | 09:51 AM
momo stallion's Avatar
momo stallion is infamous around these parts
A bit of a thread resurrection here due to reading that other thread about firestone screwing up that guys rails.
I have no problems with a traditional jack + stands but with the vantage, the jack point is the same as the stand location. That along with the way modern cars are going is enough to make me get a set of Quick Jacks.
Costco is running the QuickJack $300 off for the BL5000TL or 7000 for $1299 right now. These cost a bit more than the previous model due to rising costs but at least you get 3" more lift in same footprint. The only issue they don't have the TLX series available. The TLX gives you 6" more footprint which clears a VH gen vantage with no issue. I cant think of any cars with less than 76" tire spread that would make the TL series a requirement over a TLX.
Old Feb 4, 2022 | 10:08 AM
I got my QuickJack back in 2016 when they first came out, I have been loving it for full maintenance on the Vantage and tire and oil change on all other cars.
Old Feb 5, 2022 | 04:39 AM
buckarooboy's Avatar
5 Year Member
buckarooboy is infamous around these parts
I find the QJ quite useful for the Aston. Thinking in hindsight, I would have preferred to purchase a version that would also lift my other vehicles. As it is now, the version I have is limited to the Aston
Old Feb 5, 2022 | 05:37 AM
usera's Avatar
5 Year Member
usera is infamous around these parts
After lowering my Aston, I have to drive up on 2X10s to get the QJ under it, other than that, this thing is a life saver.
Old Feb 5, 2022 | 08:28 AM
deckman's Avatar
I like mine. It's really not that much easier than jack stands, but there is better peace of mind for me. When I got mine on sale a few years ago, I think they were under $1k
