quickjack 5000 lift of v8 vantage
Old Aug 12, 2018 | 02:50 PM
buckarooboy's Avatar
5 Year Member
buckarooboy is infamous around these parts
purchased a quickjack 5000 with a rating of 2273 kg (tare wt aston is 1630kg) and lifted the vehicle up for the first time today. This in preparation for future work on it like oil changes etc. I enclose pics FYI. I purchased lift point blocks from Matt at HSM precision which fit perfectly in the lift point holes (thanks Matt). The custom blocks from HSM have grommets which allow them to remain attached to the vehicle when you lower it; thus no need to realign. The quickjack gives me good height and now that I have figured out the layout and geography of the underside in relation to the jack, things should go more smoothly
The jack with the custom blocks and support rubber blocks just barely fit on the underside, so I cut out 4 pieces of 3/8 plywoo x2 to give me a bit more height when maneuvering the jacks under the car.
custom rear lifting block (hole is circular) and there were grommets in the rear holes but not the front
custom front lifting block (hole is oblong)
Old Aug 12, 2018 | 06:08 PM
handyman2009's Avatar
Veteran: Canadian Forces
I have been using my QuickJack for 3 yrs now and love it, makes working on these cars so much better
Old Aug 14, 2018 | 02:34 PM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
Me too! Also using the lift pads from Matt.
Old Aug 15, 2018 | 01:54 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Is the jack wide enough? Or are there two sets?
What does it cost?
it looks great!
Old Aug 15, 2018 | 04:29 AM
What does it cost?
it looks great!
Yes there is one for each side of the car, it also has an hydraulic pump and a up/down remote controller... There are different size 3500lb, 5000lb... I got the 3500lbXL and it was just about $2000 Canadian, great investment to do any work on the car. Each Ram or side weigh about 75lb and it takes about 5min or so to set them up and start lifting the car.
Old Aug 15, 2018 | 10:58 AM
Well then Matt the QuickJack is not for you as it only goes up about 21 inches or so
Old Aug 15, 2018 | 11:06 AM
Yorick's Avatar
Yorick is infamous around these parts
Regarding the holes at each of the jacking points: Are all 4 of them supposed to have the sealing plugs in them when the jacking points are not being used?
Old Aug 17, 2018 | 07:16 PM
ser1992's Avatar
ser1992 is infamous around these parts
Do authorized dealers use those plug areas in lifting cars? I was at a authorized dealer service area here in LA and they were picking up V8Vs with standard round rubber jack pads near those rubber plug areas but they left didn't unplug them or use machined pads with special fitted posts or anything.
I took these in their service area:
Old Aug 21, 2018 | 10:42 AM
XJRS Owner's Avatar
They should be removed and replaced after jacking, but lots of dealers don't bother and they end up squashed and then fall out, or after being removed aren't replaced. You can get some (or similar) at your local hardware store if it matters to you. Even a piece of duct tape will work (and doesn't need to be removed when jacking).
Old Oct 27, 2018 | 10:56 AM
stealthn's Avatar
stealthn is infamous around these parts
Love the quick jack for my Cayman, wondered how I survived this long without one. Just getting a new to me 2010 Panamera Turbo, so I hope to get it weighed right away to see if it’s light enough for the quick jack.
i can’t imagine doing work without it now
Old Oct 27, 2018 | 04:00 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Does anyone use old hockey pucks at the lift points..
Old Oct 27, 2018 | 08:15 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
I use a two 2x4 3 inches long and dipped in liquid rubber and works great and cost me $6.
Old Oct 29, 2018 | 07:10 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
My Pucks by HSM Matt wont stay in the holes, so getting them lined up and lifting my QJ is almost impossible. So, like a few members I just went without and just used the 4" rubber pads in the same spot. Worked just fine IMHO.
Old Oct 31, 2018 | 04:55 PM
Irish07@VelocityAP's Avatar
Yep, did it for years. Actually have a bucket of pucks.. I'm Canadian eh!
I would just use the adjustable pads to lift on the rubber plug bungs, if I needed more clearance, on came the hockey pucks. If I was using a regular floor jack, slapped on a puck and lifted.
If you need more of the rubber bungs, its a 20mm generic size. Aston also sells them, 6G33-N806457-AA. Sold individually, bring buckets of cash, think it's something like 0.60-1.00USD each.
Old Oct 31, 2018 | 05:07 PM
For Canadian people here I just saw the QuickJack 5000 in the CanadianTire flyer for $1299
